Author: Subject: 12mm fuel filter
Ugg10
posted on 24/4/15 at 09:02 PM Reply With Quote
12mm fuel filter
Probably been asked before but before I spash out on a sytec filter does anyone know of an oem fuel filter that has 12mm push on connectors, and if so which car is it from?
Many thanks in advance.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
se7ensport
posted on 24/4/15 at 09:28 PM Reply With Quote
When I was looking it this turned out to be the best value, yes sytec, but reasonable pricing as it isnt blinged up: eBay Item
rachaeljf
posted on 24/4/15 at 10:29 PM Reply With Quote
I use these people
http://www.inlinefilters.co.uk/Filters-Fuel/Inline/Metal/FBW-BF7693
Ugg10
posted on 25/4/15 at 09:41 AM Reply With Quote
Many thanks both. Will have a look at the in-line filters one and see what mounting I can find for it, the Sytec spring mounts will probably fit, will cost it up later.
Paul Turner
posted on 27/4/15 at 01:00 PM Reply With Quote
I have had a Sytec billet filter on my Seven for just over 10 years now. It was not cheap and the argument about the extra bling is just plain stupid, you cannot see it unless you are road kill.
But over those 10 years it has proved itself to be quite a decent buy. When I changed fuel pipes due to the rubber turning to Gorilla snot it was simply a new union instead of a new filter and the replacement filter elements are peanuts compared to a complete new unit.
