<<  1    2  >>
Author: Subject: Force Wheels
peter030371
posted on 8/2/17 at 03:45 PM Reply With Quote
Originally posted by Samuele
there would not be any advantage to produce titanium.
because titanium weighs more than aluminum.
maybe if you want to go to extremes you can replace the 20 bolts holding the rim star with other titanium.
although the weight savings would be related.
I was only joking
It may be heavier but its also stronger so you can use less of it...... I will shut up now
Samuele
posted on 8/2/17 at 04:26 PM Reply With Quote
I was only joking
do not mess about these things Peter.
This is serious stuff. :-) ;-)
Jokes aside,
you can use less material seen its greatest strength and absolutely correct.
I had previously done a similar thought.
thinking only change the center of the rim star.
but only the material cost more than € 1000
not including labor.
Although it would have its charms.
peter030371
posted on 8/2/17 at 04:38 PM Reply With Quote
Jeff, how deep are your pockets?
jeffw
posted on 8/2/17 at 06:58 PM Reply With Quote
Deep but Titanium is not the ideal material in this instance I would think.
jeffw
posted on 8/2/17 at 06:59 PM Reply With Quote
beautiful rims,
both of aesthetics as well as weight.
if you get a chance,
you could have the total weight of the rubber to the rim 8 "
I'm doing a thought ...
I'll try and sneak the scales out of the bathroom and put a wheel+tyre on it.
jeffw
posted on 9/2/17 at 12:51 PM Reply With Quote
First pair of 10" rears are here
Andy D
posted on 9/2/17 at 02:40 PM Reply With Quote
Is the other one black?
jeffw
posted on 9/2/17 at 02:52 PM Reply With Quote
Yeap
Samuele
posted on 9/2/17 at 05:06 PM Reply With Quote
beautiful
jeffw
posted on 9/2/17 at 05:09 PM Reply With Quote
Carl at Force Racing does lots of Titanium work as well so you will find a kindred spirit.
http://www.force-racing.co.uk/front-suspension/
TimC
posted on 10/2/17 at 08:50 AM Reply With Quote
Do these come in brown?
jeffw
posted on 10/2/17 at 08:51 AM Reply With Quote
If you want them too, yes.
CNHSS1
posted on 10/2/17 at 11:56 AM Reply With Quote
Nice rimmage Jeff
Combo of splitties and slicks makes a big weight saving over 1Bs and cast wheels doesn't it
jeffw
posted on 10/2/17 at 05:59 PM Reply With Quote
Certainly does....
<<  1    2  >>
