Author: Subject: Aerodynamics
olimarler
posted on 17/5/17 at 08:31 AM Reply With Quote
Aerodynamics
Hi All,
In the process of planning the improvements in the aerodynamics of my 7.
Got my front winglets ready to go on.
Also will be looking at front splitter, Ali underfloor and then rear diffuser.
I've seen a few &s with the rear spoilers.
Question is how are people mounting these to the rear role cage?
Oli
loggyboy
posted on 17/5/17 at 09:32 AM Reply With Quote
Improve it in what way?
Do you want less drag or more grip? or both?
Mistral Motorsport
benchmark51
posted on 17/5/17 at 09:44 AM Reply With Quote
One of the best things I did to my locost 7 was the rear diffuser. I made a flat 1.2mm plate to fit between the rear of the tub to rear of the floor. Cut a 6inch hole beneath the diff. This was bonded and riveted to the chassis. Then made 4 fins from ally and bonded and riveted them to the plate. The difference was quite a surprise, so much quicker. The 'parachute' effect was gone!
olimarler
posted on 17/5/17 at 10:15 AM Reply With Quote
Bit of everything really.
Looking at the underneath of the car is a giant parachute!!
Just had thoughts about the rear spoiler too
loggyboy
posted on 17/5/17 at 10:23 AM Reply With Quote
Without going for a rebody, (and moving away from a 7-esque car) the underbody is the only real way to reduce drag. Although a half torneau cover and aeroscreen (if you have a full screen) will also help a lot.
Unless you are experiencing less grip at the rear at high speeds, a spoiler will just add drag. (and IMO look ubergay).
Mistral Motorsport
sam919
posted on 17/5/17 at 11:26 AM Reply With Quote
One thing you'll find with a full undertray is the lack of air escaping from the now enclosed engine bay, so engine temps will increase if you dont provide a suitable escape path. You'll find your feet will get hot, hence the duct on the bonnet on the drivers side at the pedal box location on some C400 caterham race cars
Anything below 70-80mph in a 7, aero, doesn't really have any valuable effect. Unless your racing, these mods are more for the look rather than anything else.
The rear aerofoil, will indeed not have any great effect apart from a good place to rest a cup of tea in the garage, it will in most cases slow you down. MSA regs, if relevant, dont allow attaching anything onto the cage like this. They have to be done directly to the spaceframe.
If you really want aero, and are prepared to go a bit mental have a look at RSP seven's, and the oroginal black brick! Oh, and at the end a picture of the nurburgring caterham that was banned for being too quick....not a wiff of aero in site....
olimarler
posted on 17/5/17 at 01:54 PM Reply With Quote
Great images!!
I have the bonnet scoop and also flared side panels. I was thinking about directing the air out of the rear clam by having some holes along it. No Gearbox in the tunnel as a BEC.
Also the rear diffuser wasn't going to be tight on the rear clam too too alow air out.
All still in planning stage so happy for ideas
sam919
posted on 17/5/17 at 02:20 PM Reply With Quote
Another angle on it here!
If we think about a lot of the formula cars where the engineering is real world, the cooling is done with radiators mounted on the side. If a radiator was mounted in this area to offer sufficient cooling, you could then remove the need for it up front which would also move the weight towards he centre. A lot of work for not a lot of gain but worthy of thought.
I noticed you've a full cage, without being hampered by MSA regs, the area between the parallel bars could be filled in, being rectangular it could be wing shaped , curved to allow flow over it and also downforce/ drag, haha.
Those squared off front cycle wings also introduce better air flow, these can be cut off 70mm above the centre wheel hubs or more, this will reduce the drag experienced on the trailing edge as air gets trapped in this area. Same with the rear arches and as you've suggested holes in the rear basket.
Good project, you should find it interesting! and if you take the 7 to the extreme, you end up with a slippery club racer!
[Edited on 17/5/17 by sam919]
posted on 1/6/17 at 07:10 PM Reply With Quote
whilst this looks good, is it schoolboy playing with photoshop or as a result of wind tunnel testing, I suspect the former.
Other than a series land rover, the lotus 7 shape is probably the worse aeorodynamic shape ever good luck with it.
sam919
posted on 1/6/17 at 07:38 PM Reply With Quote
You seem to be historically up on the black brick caterham?
sam919
posted on 1/6/17 at 07:48 PM Reply With Quote
No real access to wind tunnels in the 70's for your typical club racer. Good article on the pioneering spirit here, where would we be without trying things out?!
http://tentenths.com/forum/showthread.php?t=129950
Mr Whippy
posted on 2/6/17 at 11:40 AM Reply With Quote
Originally posted by 02GF74
Other than a series land rover, the lotus 7 shape is probably the worse aerodynamics shape ever good luck with it.
Depends on your point of view - aerodynamically the landrover is perfect as it prevents you going too fast and crashing due to the fantastically bad handling and dodgy brakes…
