Author: Subject: Girling Brake Master Cyl - ID
sooty
posted on 30/3/18 at 08:50 PM Reply With Quote
Can anyone identify a Girling Tandem Brake Master Cyl 74660176 with its mounting holes Horizontal.
[Edited on 30/3/18 by sooty]
Sylva Striker
2.0ltr Silvertop Zetec on 45 Webers with Megajolt V3
sooty
posted on 30/3/18 at 09:43 PM Reply With Quote
This the cylinder
Sylva Striker
Dick Axtell
posted on 31/3/18 at 08:42 AM Reply With Quote
Hi Sooty, thanks for posting that photo. "A picture is always worth......." etc.
Check the digits on that plastic ID band round the mcyl casting. Looks like it is black. If so mcyl has 22.2mm bore. But those digits (e.g. 660** ) will give the true identity.
74660176 is only the casting part number, and this may well have been used for several different mcyls.
[Edited on 31/3/18 by Dick Axtell]
sooty
posted on 31/3/18 at 12:25 PM Reply With Quote
Thanks,
But if you look close up its more of a purple/plum coloured band.
Cant give any more detail, local motorspares has it to try and identify.
Sylva Striker
Dick Axtell
posted on 31/3/18 at 02:31 PM Reply With Quote
Sooty, if that's "plum" coloured, then definitely NOT 22.2mm bore. Reversing from the casting 74660167 has revealed that your example is in fact 17.8mm bore. And it came from one of the older Fiesta 1100 variants, (76 - 83).
sooty
posted on 31/3/18 at 03:14 PM Reply With Quote
thanks
Now my problem my local spares peep can't locate one.
Any suggestions where I might get one other than fleabay. Tried Eurocarts, not listed.
[Edited on 31/3/18 by sooty]
Sylva Striker
Angel Acevedo
posted on 2/4/18 at 03:21 PM Reply With Quote
Originally posted by sooty
thanks
Replacing with a cylinder that physically fits the bolt pattern is possible even if it is not the exact same diameter.
Be aware that bigger Cylinders will give firmer pedal with shorter trhow and smaller pedals will give softer feel with longer throw.
Second option may not lock both pair of wheels though.
HTH.
