Author: Subject: UNF 35 suspension bolt nut size?
petroldiaries
posted on 2/4/18 at 08:50 AM Reply With Quote
Hi does anyone know the nylon locking nut size for the UNF 35 wishbone suspension bolts where they mount to the frame? Am I right in assuming only the nut should be replaced as best practise and not the whole bolt? Does anyone know a place to buy the nuts only with the correct strength rating?
Thanks in advance
[Edited on 2/4/18 by petroldiaries]
cliftyhanger
posted on 2/4/18 at 09:01 AM Reply With Quote
That is UNF, not UNC. And the 35 has nothing to do with size.... but it may be tensile strength???
Measure the diameter of the bolt, but I suspect it is 3/8, near enough 10mm. And uses a 9/16 spanner.
If you replace, use 8.8 rated bolts, and certainly not stainless.
[Edited on 2/4/18 by cliftyhanger]
petroldiaries
posted on 2/4/18 at 09:08 AM Reply With Quote
Thanks for spotting the typo I've edited now to state UNF. I thought (maybe wrongly) 35 was the amount of thread e.g. 35mm on the end of the bolt. Thanks for the info mate
gremlin1234
posted on 2/4/18 at 09:59 AM Reply With Quote
you could look at namrick
http://www.namrick.co.uk/acatalog/Home_U_N_F_Bolts___Nuts__15.html
though they were used on mini/triumph/landrover et al, so most classic parts suppliers should have them
what is you hub from?
ps, the radial lines on the head indicate the strength
jacko
posted on 2/4/18 at 10:14 AM Reply With Quote
What size spanner fitted the bolt ie
9/16 Af 5/8 Af
the bolt could be 3/8 or 7/16
jacko
petroldiaries
posted on 30/4/18 at 04:52 PM Reply With Quote
9/16 Af 5/8 Af
jacko
Cheers Jacko
It was 7/16, I wanted to be sure on strength and thread etc. I called Westfield and it's the only size they do for suspension bolts, so was worth the 90pence each for the piece of mind;o)
Front is all fitted now in my latest vid
https://youtu.be/MDqq12BPLdw
[Edited on 30/4/18 by petroldiaries]
