Author: Subject: Mangoletsi Linkage Hitting Fuel Line
mark.silcock
posted on 12/2/19 at 08:58 PM Reply With Quote
Is anyone else running a Zetec on DCOEs and using the Mangoletsi linkage system?
I have installed one at the weekend and surprised the arm the cable pulls on hits the fuel line running between each carb, see the video below.
https://photos.app.goo.gl/dYa9D252E7YFRccn6
I would have thought this was a pretty typical install so am surprised by the issue?
I have been looking for a way to feed the carbs from below but the fittings dont seem to be that obvious.
This photo looks like a nice option but I can't seem to find the fittings I suspect they are using 7/16 hydraulic lines.
https://photos.app.goo.gl/Le22NdEhEabJ1iU4A
Does anyone have a similar install or suggestion? Cheers
perksy
posted on 12/2/19 at 10:34 PM Reply With Quote
The fuel pipe should run the otherside of the mechanism on the Air filter side
If you spin the pipe fittings on the carbs (inc the fuel pipe) 90 degrees it should work
You'll need to disconnect either the mechanism or more easier the fuel fittings on the carbs first
Also as it stands now you won't be able get the jet covers off either of the carbs
cliftyhanger
posted on 13/2/19 at 07:18 AM Reply With Quote
And fit some proper R9 or 14 hose that is suitable for todays fuel (R9 is NOT suitable)
And don't get the cheap fake stuff either....
mark.silcock
posted on 13/2/19 at 08:18 AM Reply With Quote
I did rotate the fittings to try and sit at the front of the carb and they wouldn't clear the front edge of the carb, and still fouled the linkage.
The position it is in the video is at its highest point to see if it cleared the linkage, the bonnet doesnt fit with the fittings set at that position so jets are the least of my worries.
cliftyhanger
posted on 13/2/19 at 09:43 AM Reply With Quote
Not sure if connectors are available that are a bit longer, so it could be tucked away by the filter?
If not you could buy straight connectors and a T, do something similar to your other suggestion, using rubber hose. Or cut up what you have, solder some olives on and do it for £1.
perksy
posted on 13/2/19 at 07:21 PM Reply With Quote
Pretty sure there's only one length of fuel fittings to the carb's, If there are longer ones available then great
The last one i set up was a 2 litre Zetec on twin 45's
The fuel pipe ran just above the air filter on standard fuel fittings
I have a photo but the site won't let me upload it
Double check everything as there's definitely something amiss...
mark.silcock
posted on 13/2/19 at 08:28 PM Reply With Quote
The fittings on this build definitely won't clear the front of the carbs. It would sit on the front edge of them but the mongoletsi mount on the top of the carb gets in the way. Has anyone got a dimension from banjo bolt to fuel line centre?
https://photos.app.goo.gl/Z4MSs3Zd8BQdtAws9
[Edited on 13/2/19 by mark.silcock]
mark.silcock
posted on 13/2/19 at 09:54 PM Reply With Quote
I was experimenting different positions.
Found this, pricey!
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F181104620325
melly-g
posted on 14/2/19 at 10:38 AM Reply With Quote
Can you get another fitting like the rear carb (Top of the Picture) on the front carb then have a T piece before that?
I might have some spare fittings!
Where are you based?
mark.silcock
posted on 15/2/19 at 09:39 AM Reply With Quote
I think I am going to get two straight pieces and run it back towards the head connect with a T then down to the regulator.
I am really surprised and confused it's not a known issue.
Frustrating there is no contact details on the Mangoletsi website. Edit I found an email address so will see what they say..... Scrap that it bounced back ;(
Based in Norringhamshire
[Edited on 15/2/19 by mark.silcock]
mark.silcock
posted on 15/2/19 at 10:10 AM Reply With Quote
????? where is that hahah
Nottinghamshire!
