Author: Subject: English axle - replacement diff pan source?
gasket999
posted on 15/2/21 at 03:11 AM Reply With Quote
Hi folks. For another, non-Locost, project I have a genuine MK2 RS2000 English axle.
The diff pan (the pressed steel part welded to the axle casing) is damaged.
Does anywhere sell a replacement weld-on pan? I know from my Land Rover projects that it’s a tricky, but doable job but I haven’t been able to find a source for English axle pans. Alternatively if any of the rally specialists do them it might be quicker just to send them the axle casing for a refurb.
Thank you.
PS: the RS2000 diff pan had a little u-shaped hoop welded onto it and I can’t for the life of me picture what it was for: any ideas?
[Edited on 15/2/21 by gasket999]
steve m
posted on 15/2/21 at 08:34 AM Reply With Quote
The U hoop. normally has a rubber insert, and its for the handbrake rod to slide into, and align
as the handbrake cable only goes to one side
Memphis
posted on 15/2/21 at 10:27 AM Reply With Quote
Thank you.
You can get a whole new axle casing for £110.
https://www.premiermotorsportdevelopments.co.uk/re-sleeved-english-axle-casings-543-p.asp
gasket999
posted on 15/2/21 at 01:39 PM Reply With Quote
Guys - thank you very much! That answers the loop query.
On the casing, I’m now kicking myself: I had seen that advert but just saw the pics of the fabricated housing. As this is a restoration I wanted an original look - which is exactly what they offer in the blurb. Just called them and they can supply exactly what I need.
That’s all the answers I needed. Thank you.
chillis
posted on 15/2/21 at 09:32 PM Reply With Quote
or this
eBay item number:
133465308828
Never under estimate the ingenuity of an idiot!
