Author: Subject: rear brake pictures
wheelsinsteadofhooves
posted on 23/2/05 at 12:28 PM Reply With Quote
rear brake pictures
hi all, im after some clear pictures of a rear drum setup on an escort axle. i have all the bits (axle, shoes, rebuild springs etc etc) but not a clue how to stick them all together. random search in photo archive so far not revealed much - any pointers???? (ps im too tight to fork on a haynes manual right now)
also, whats the noggin called that the handbrake cable attaches to. im missing one and need to get it from a scrappies but local scrappies posh and need to ask for bits by name.
thanks all in advance.
lewis635
posted on 23/2/05 at 12:37 PM Reply With Quote
If you look in my picture archive you will see the rear set up, not great pictures but better than nothing, as for the handbrake actuating lever, i had a lot of trouble getting hold of a set and ended up buying a whole axle,(thanks hornet)
If you have to go down this route then there is no differance between the standard drum size and the larger 9" drums so any axle will do, hope this helps
[Edited on 23/2/05 by lewis635]
bigbriglasgow
posted on 23/2/05 at 01:38 PM Reply With Quote
please find the attached file as scanned from mk2 escort manual
bigbriglasgow
posted on 23/2/05 at 01:39 PM Reply With Quote
posted on 23/2/05 at 02:04 PM Reply With Quote
forever in your dept birbri, also lewis. think i may just be able to work it out!
thanks again,
zane
bigbriglasgow
posted on 23/2/05 at 04:31 PM Reply With Quote
No problem usualy me thats asking for help so makes a change that i can help someone
Brian
