Author: Subject: handbrake cable
chriscook
posted on 21/9/05 at 05:47 PM Reply With Quote
handbrake cable
Does anyone know what vehicle the Caterham handbrake cables originate from? I
don't know if there is more than one type but it is the one that uses a
pulley wheel for the left/right balance. Like in this picture:
http://www.alcester-racing-sevens.com/handbrake_pulley.jpg
The rear cable is probably sierra but the front cable with the pulley looks like it could do just the job on my phoenix.
Thanks,
Chris
Tangerine Scream
posted on 22/9/05 at 01:36 PM Reply With Quote
Hi Chris
Replied on sevens list but didn't see it appear, so I put my 2 penneth in here :-)
I used one of these
Brake adjuster
Brake adjuster
from here
http://www.trailerpartswarehouse.co.uk/trailer_parts_spares/trailer_suspension.html
Hope this helps
Mix
posted on 22/9/05 at 03:41 PM Reply With Quote
Very useful site
Many thanks Mick
chriscook
posted on 22/9/05 at 05:30 PM Reply With Quote
Steve,
That looks ideal - thanks. just a couple of questions...
Can the pulley wheel be removed to put the cable in or does it have to be threaded through? Also how big is the wheel - it look about 25-30mm to me?
Chris
Tangerine Scream
posted on 22/9/05 at 09:46 PM Reply With Quote
As best as I could measure it (in a cold scottish rainy garage!), the wheel is 1.5" in diameter and the threaded rod is 5/16.
The spring clip (clipped around the body of the fitting) swings off sideways and the pin pops out.
Adjusting the bottle screw is far easier than using the adjusters on the Sierra cable as well.
