Author: Subject: Steering knuckle joints.
Sean
posted on 4/2/06 at 07:59 PM Reply With Quote
I am re rooting my steering column which uses triumph spitfire parts. However, I need to source some parts. i.e the extension bar that sleeves inside the upper column ( the bit with the splines on it ) and a knuckes joint that will fit between this and the rest of the original part. In the end I hope to go from the column with a knuckle at the end, off at an angle of about 25 degs, then through another knuckle turning back to locate with the rack. So 2 knuckle joints all to go round the headers. Does anyone know where such knuckle joints and steering column extensions can be obtained?
Hope this make some sense. A tad diff to explain in writing.
Schrodinger
posted on 5/2/06 at 12:41 PM Reply With Quote
Try Car Builder Solutions
http://www.nfauto.co.uk/download/cataloguejuly2005.pdf
page 15 of the catalogue I think is what you are after
Keith
Suffolk
posted on 5/2/06 at 01:28 PM Reply With Quote
Rimmer Brothers have an on line catalogue --- I suspect the part you need is the steeering shaft UJ used on the Triumph 2000 (manual rack) , Toledo, Dolomite --- you may need two.
I think the Allegro also used the same part.
http://www.rimmerbros.co.uk/
A cheaper scrappy alternative might be to lool at using parts from a FWD Mk3 Escort
posted on 5/2/06 at 01:30 PM Reply With Quote
Like this
TR7 from rimmer bros catalogue -- almost the same as Spitfire Rescued attachment 67.gif
Sean
posted on 5/2/06 at 06:38 PM Reply With Quote
Thanks chaps, that's very helpful. Funnily I had just done some checking on the Rimmer site and came up with the same conclusion. All I need now is a good triumph breakers to get the bits from.
dave-69isit
posted on 5/2/06 at 08:33 PM Reply With Quote
tr7 parts
i have just striped a tr7 based robbin hood still have colum and extension let me no wich pieces you need also uprites if needed
Sean
posted on 5/2/06 at 09:03 PM Reply With Quote
It is the ukc2449 knuckle and the extension that fits into it as shown on the diagram. It would be great if you had those bits. Thanks
