Author: Subject: Mounting Sierra Rear Brakes
James
posted on 17/3/03 at 04:21 PM Reply With Quote
Want to finish off my rear uprights tonight- thing is, can't remember where the brakes should go ie. which point of the clock are they?
I know that the MK uprights for discs are setup such that the brake callipers are at about 1-2 o'clock but looking at the trailing arms/hubs from my 4x4 Sierra gives the impression that the callipers were at 12 o'clock.
Whichever I go for does it matter in terms of braking capability or are the callipers in these positions for another reason ie. ease of fitting brake lines etc.
Any info' gratefully recieved!
Thanks,
James
carnut
posted on 17/3/03 at 04:52 PM Reply With Quote
It shouldn't make any difference with braking power but you have to remember where the bleed screw is because you may have to remove the brake caliper from its mount to bleed them.
Ive been toying with the idea of mounting the calipers in the 6 o'clock position to lower the centre of gravity. Whether I will of not is a different matter. (this is what McLaren do on there formula 1 cars)
Viper
posted on 17/3/03 at 06:11 PM Reply With Quote
the sierra ones do mount inthe 12 o'clock position, not sure about the 6 position suceptable to damage etc, Take a look at my photo's to see how i have done mine..
bob
posted on 17/3/03 at 06:59 PM Reply With Quote
James
The MK ones on my indy are at about 11 o-clock,pretty much as they are on sierra/granada when born.
however,remember the bleed nipple is not the only issue here as the handbrake cable can be a bit painfull as well.
You can just see the rear cali's in this pic
bob
posted on 19/3/03 at 10:01 PM Reply With Quote
JAMES
Sorry mate,duff info on my behalf
My rear calipers are at about 10 o-clock,theres a pic in archive if its working.
dutchsuperseven
Builder
Posts 105
Registered 28/2/03
Location Born, Holland
Member Is Offline
Photo Archive Go!
Building: Locost-clone, powered by zetec 1.8, sierra type N9
posted on 30/3/03 at 10:25 AM Reply With Quote
Mounting Sierra rear brakes
This could be usefull: It is almost impossible to get the handbrakecables right trough the chassis, so I switched the brakes ( sadly still drums ) from left to right so the cables exit at the rear. This could be done with the caliper to ( just mind the nipple!
