graememk
posted on 4/5/06 at 08:31 AM |
what sealer to use with petrol
i'm not sure that the gasget is sealing around the petrol pump in the tank and i'd like to put a bead of sealer around it then refit, what
can i use?
ned
posted on 4/5/06 at 08:36 AM |
james asked this question not long ago, maybe worth a search...
Ned.
beware, I've got yellow skin
graememk
posted on 4/5/06 at 08:44 AM |
Loctite 5368 ?
posted on 4/5/06 at 09:46 AM |
yep, do a search for this.
but to help a little bit, I use the red semi-hardening hermatite stuff anbd it is fine (the blue stuff says not for immersion in petrol on the back -
this was used, not buy me, before and had gone soft).
posted on 4/5/06 at 09:59 AM |
Don't put sealer near it --- if you can avoid it.
[Edited on 4/5/06 by britishtrident]
Marcus
posted on 4/5/06 at 11:43 AM |
Twas I who used blue stuff to seal sender unit on tank.
NEVER AGAIN!!!
Still finding it in fuel filter, fortunately, that's as far as it's getting now I changed filters!
Marcus
Marcus
Because kits are for girls!!
