Author: Subject: Clamping handbrake cable
andyace
posted on 28/8/06 at 10:22 AM Reply With Quote
I have cut the sierra handbrake cable and now need to reclamp it.
Any pointers to a suitable clamp which will be SVA suitable.
I have seen this one?
http://www.zoomkarts.com/product.asp?productID=120
fesycresy
posted on 28/8/06 at 02:04 PM Reply With Quote
Use Bulldog clips (x4) two on each side.
Get them from any motor factors. I picked mine up from mac1.
locoboy
posted on 28/8/06 at 04:35 PM Reply With Quote
Bulldog clip??????
What are they?
Locoboy
The Doc
posted on 28/8/06 at 05:12 PM Reply With Quote
What no Nipples!
Are you nippleless?
andyace
posted on 28/8/06 at 07:56 PM Reply With Quote
Sorry no nipples
Cable cut half way to get it through to lever (GTS chassis), cable looped around standard sierra half moon thingy.
Just needs to be clamped on one side.
I thought bulldog clips were for stationery , I am sure you mean something else !
BKLOCO
posted on 29/8/06 at 08:28 AM Reply With Quote
You need "U" clamps from a boat chandlers. Used for the very purpose of connecting 2 wire ropes.
These Click Here
Or you could make some like mine
Description Handbrake cable clamps
[Edited on 29-8-06 by BKLOCO]
NS Dev
posted on 29/8/06 at 12:02 PM Reply With Quote
I just drilled a hole through a short M12 bolt and used that as a clamp - an idea copied from somebody else on here but I can't remember who.
It's boxed in anyway so no SVA questions.
DarrenW
posted on 30/8/06 at 02:19 PM Reply With Quote
Bloody SVA made me take off tunnel cover to inspect mine. I used cable clamps as used for clamping wire ropes. 2 on each side. Gosforth failed them. I had to change to nipple ended cables. Since then there has been investigation by SVA and clamps now OK as far as i know. Its worth phoning your local centre up. I used the method advised by Mac#1 which passed loads of times at Nottingham. I think Gosforth were just being picky at the time. Im sure clamps are used by trailer manufacturers for their main cable operated brakes.
