Author: Subject: Top wishbones (Oval) MK Indy
Pants On Fire
posted on 19/12/06 at 09:52 PM Reply With Quote
They just dont look right, are they the right way round?
Offside
Nearside
Pezza
posted on 19/12/06 at 09:55 PM Reply With Quote
Looks right to me, mine are oriented the same way.
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
mookaloid
posted on 19/12/06 at 10:04 PM Reply With Quote
Looks ok to me too.
If you look down from above the top ball joint should be behind the bottom ball joint. (imagine dangling a plumb line)
This helps give it some self centering.
Mark
Pants On Fire
posted on 19/12/06 at 10:06 PM Reply With Quote
Thanks guys, longest side to front is what I thought.
And it self centres
Without valve springs in the rack and without 23 degrees of toe in, just lots of chalk lines on the garage floor and a geometry set
zxrlocost
posted on 19/12/06 at 10:12 PM Reply With Quote
does it self centre properly dude when you drive it not on the spot
Pants On Fire
posted on 19/12/06 at 10:15 PM Reply With Quote
It self centres when I sit in it in the garage and go brmmm brmmm.
It certainly doesn't fly back but does come back to rough centre at wet, greasy public road speeds as tested today.
zxrlocost
posted on 19/12/06 at 10:21 PM Reply With Quote
ok mate good luck and i hope it works for you
my Indy self centred on the spot but not when driven hence why I had to do all the stuff
Pants On Fire
posted on 19/12/06 at 10:30 PM Reply With Quote
I've got 6 land rover valve springs at the ready in case it didn't work!
Still not 100% as the camber looks a bit excessive to be honest.
zxrlocost
posted on 19/12/06 at 11:00 PM Reply With Quote
if you searcxh for
HOW to MAKE YOUR INDY SELF CENTRE
thats how I did it and it worked if you have any probs
goodall
posted on 19/12/06 at 11:05 PM Reply With Quote
does anyone know the engineering reason to make the bars oval rather than round?
posted on 20/12/06 at 09:25 AM Reply With Quote
Originally posted by snoopy
simple fact there isnt one it was only done because gts started to produce oval ones for the indy which were truthfully not pretty
Not pretty? Is that because the GTS ones were triangulated rather than the "pre-failed" curved design? Give me engineering purity over aesthetics anyday.
goodall
posted on 20/12/06 at 12:23 PM Reply With Quote
The reason I asked is because the oval bar would have a worse neutral axis and you would also loose the all angular strength of the round bar which would therefore make the oval bar the poorer option because it would have to be heavier to have the same capabilities of round. Anyone out there with a engineering degree could show a proof for the reason to chose oval? I've always been told by my father (civil engineer for 30 sumthing years) that round bars have best structural strength but were used less because there difficult to work
[Edited on 20/12/06 by goodall]
posted on 20/12/06 at 08:01 PM Reply With Quote
I think the reason for using oval is 99% aesthetic, though the failures of the lower wishbones often discussed on here tend to show the rearmost part of the wishbone failing by bending towards the back of the car (i.e. failure likely occured under braking) so an oval tube of simmilar weight to round would be stronger in this axis.
Uphill Racer
posted on 21/12/06 at 12:06 AM Reply With Quote
Think u r spot on mike, u wouldnt build a chassis full of bend would u ? The first time I saw that top wishbone I was glad it wasnt on my car
