Author: Subject: Quickest, easiest, cheapest SVA front end Option?
The Doc
posted on 1/8/07 at 10:16 AM Reply With Quote
Covering up the steering/suspension gubbins
Any Ideas?
Speed and cost effectiveness to the fore!
just for the SVA
posted on 1/8/07 at 11:24 AM Reply With Quote
Nut covers for nuts(!)
Split some water hose, wrap round offending tie-rod nuts etc and tie wrap in place. Cut some self-adhesive thick foam and wrap around knarled nut @ bottom of suspension (adjustable spring seat) with tie-wrap as added precaution.
posted on 1/8/07 at 11:42 AM Reply With Quote
or do what Dax do and fit round tube dummy bumper bars which preclude the SVA man from touching your front suspension with his ball Rescued attachment rushmain.jpg
chockymonster
posted on 1/8/07 at 01:16 PM Reply With Quote
unless you get it sva'd at southampton!
He wanted everything behind the bar padded in case someone walked into so that if they put their hand out they wouldn't get injured
posted on 1/8/07 at 02:00 PM Reply With Quote
It still seems strange that the SVA people want to protect someone that stupid (or unlucky) that they manage to make contact with something you can only just reach if you're trying (!) yet don't give a monkeys nuts about the glowing exhausts waiting to give people 3rd degree burns....
iank
posted on 1/8/07 at 02:05 PM Reply With Quote
Strange the bumper defines the floor line and everything under the floor is 'free' by the definition of the SVA manual. It goes into great detail of how it's measured. If the tester can ignore it why is it in the manual.
If you lay on the ground and wave your arm under my tintop you can catch exposed bolts
Anonymous
