Author: Subject: diff for my midget axle
westindy
posted on 8/8/07 at 06:53 PM Reply With Quote
I'm looking for a higher ratio diff for my MG Midget/Sprite - circa 3.38 ( has a 3.9 at the moment ) anyone who what will fit and source of supply?
posted on 8/8/07 at 07:27 PM Reply With Quote
Wasn't the Riley 1.5 or Wolsely 1500 the highest ratio that would fit the Midget axle? probably rarer than rocking horse manure though
cs3tcr
posted on 8/8/07 at 08:41 PM Reply With Quote
The late (post 1978) Midgets use a 3.7:1 diff, but these seem to be hard to find. As for something lower, i dont believe they made any.
posted on 9/8/07 at 08:01 AM Reply With Quote
It is an A series axle
Diff was used in quite a few cars (some of which had B series engines) lots of short ratios were made for A35 vans and the like but as it was only used in cars up to 1600cc you will be pushed to find a longer ratio than 3.77.
Usual way round it is to fit a type 9 gearbox.
posted on 10/8/07 at 09:36 AM Reply With Quote
This this the same axle as the Marina/Ital used? What ratio did the 1800 versions use?
posted on 10/8/07 at 12:14 PM Reply With Quote
Marina/Ital was a Triumph Toledo/Dolomite axle modified for leaf springs. Different whel PCD
MGB (except for the first year or twos of B production) was a much heavier Salsbury unit
[Edited on 10/8/07 by britishtrident]
