Author: Subject: zx9r clutch slip!
westindy
posted on 11/10/07 at 05:15 PM Reply With Quote
zx9r clutch slip!
I've a zx9r with clutch slip - put in new original plates plus barnett springs and castrol GPS oil and it still slips ( tried EBC clutch with the same result ).
any ideas???????????
posted on 11/10/07 at 05:26 PM Reply With Quote
Doesn't sound right!!!
? warped basket or something like that preventing full release.
Otherwise could it be a M/C issue especially if you've been using a Easibleed @ high pressure.....
strange.... Barnetts and OEM plates are usually a good combo. Even EBC springs are okay until they turn to molten chocolate....
russbost
posted on 11/10/07 at 06:33 PM Reply With Quote
Got to be something holding the clutch partially out shirley - pedal/mc issue?
roadrunner
posted on 11/10/07 at 07:01 PM Reply With Quote
Mine is also starting to slip, at fisrt only at high revs in sixth, then last night coming up the slipway on to m62, it was slipping a bit through the gears.
Jimbob
posted on 11/10/07 at 08:05 PM Reply With Quote
mine gives a slight slip at peak power but only
in second tho
Barnet springs sort this?
posted on 11/10/07 at 10:58 PM Reply With Quote
Did you ask for uprated Barnett Springs... some other mechanical problem if this is the case. Also overfilling it can also create slip as the oil cannot be forced out between the plates them selves...
[Edited on 11-10-07 by Hellfire]
