westindy
posted on 12/10/07 at 07:53 PM |
Type 9 5 speed gearbox
Anyone know the difference between a type 9 Gearbox from a Capri from a Sierra, I just need one for my K series?
Hammerhead
posted on 12/10/07 at 08:06 PM |
search some of my threads on here. I had to use a type 9 from a v6. either sierra or capri will do. you then have to cut 13mm or so off the input
shaft. Also depends which k you have 1.4 1.6 or 1.8.
Let me know if you have specific questions as getting it wrong is costly.....i learnt the hard way
snapper
posted on 13/10/07 at 07:49 AM |
Caterham bell housing spacer is 30mm and could eaisily be cut down to fit, easier than cutting the input shaft and leaves the box intact and easier to
swap out in the future. V6 box has better ratios.
I eat to survive
I drink to forget
