Author: Subject: Fuel pump pictures also 954 pressure?
Jay k
posted on 21/1/08 at 01:30 PM Reply With Quote
I am going to use a blade pump in the bottom of my MK tank has any one got any photos of this in place so I can see if the pump sits flush with the tank or if a recess is needed in the tank.
Also the 929 fuel pressure is 43 psi approx does anyone know what the 954 runs at as I can get one of these pumps cheaper.
Thanks in advance
PAUL FISHER
posted on 21/1/08 at 02:21 PM Reply With Quote
The 929 and 954 pumps both run at the same pressure,but are not the same,ie you could not fit the 929 pump in a 954 tank on the bike the bolt holes are different,but as your mounting yours in your own tank this will not be a problem..
Sorry Ive not got any pictures of mine mounted in the tank,but it was just bolted flush in the base of the tank,I did not have a additional recess/sump in the base of my tank,the standard mk tank is baffled inside,and there is a small sump built into the 929/954 pump,with this set up I had no problems with fuel starvation on the road or track
