Author: Subject: Pivot points for pedals? How?
Mave
posted on 28/7/08 at 05:47 AM Reply With Quote
I'd like to pick your brains on the following; I'm considering making a new set of pedals, but I'm stuck on how to make the pivotpoints. I don't have access to a lathe, so I need to find a solution that doesn't require any machining. I just can't think of a good solution......
Does anyone have a good idea?!?
Marcel
Macbeast
posted on 28/7/08 at 06:14 AM Reply With Quote
On mine, the pivots are 10mm id tubing welded in at right angles to the flat pedal strip. Will post a pic later if you like.
Mr Whippy
posted on 28/7/08 at 08:31 AM Reply With Quote
I made a set using the same plastic bushes, crush tube and bolts used for the wishbones, worked very well.
posted on 28/7/08 at 09:21 AM Reply With Quote
These any use...?
http://www.locostbuilders.co.uk/viewthread.php?tid=91369
Steel plate for the pedal arms with steel tube welded in at right angles to the plate to provide a bush tube/pivot point. Top or bottom mount as preferred.
Marcus
posted on 28/7/08 at 11:37 AM Reply With Quote
I butchered a Manta pedal box for the pivots, cut the pedals off, turned it upside down and re-welded, making them floor mounted. Works a treat and FREE
Marcus
Because kits are for girls!!
Howlor
posted on 28/7/08 at 12:47 PM Reply With Quote
How bout these 4.99 bargain.
Click
Macbeast
posted on 28/7/08 at 04:29 PM Reply With Quote
A bargain yes - for an automatic box ?
Mine
Pedal
Pedal
[Edited on 28/7/08 by Macbeast]
