Author: Subject: Propshaft to sprocket adaptor
Echidna
posted on 18/10/08 at 07:43 PM Reply With Quote
This is my Sierra propshaft. I just removed the "doughnut" and i came with this triangle flange. Could someone suggest how i am going to connect this 3-bolt flange with the 4-bolt sprocket adaptor fitted to the motorcyce engine? Rescued attachment Photo-0108.jpg
adam1985
posted on 18/10/08 at 07:46 PM Reply With Quote
it needs to be profesionaly adapted and balanced have a look at what happens to ones that have broken due to being out of balance its not a diy job
NigeEss
Hang on, I'm just popping next door to see the rest of the picture..............
..........................................back now
You need to chop off the triangle and weld a four bolt flange on.
Most recommend a specialist prop shop as it'll need balancing after.
Echidna
posted on 18/10/08 at 07:47 PM Reply With Quote
Yes, i know that the shaft should be professionally balanced, the question is how to adapt this flange to the sprocket adaptor. Any pictures from anyone?
Andy B
posted on 18/10/08 at 08:05 PM Reply With Quote
I would send the prop to someone like bailey morris and ask them to convert it to a four bolt flange and then balance it. Having seen 2 let go this season, both of which cut a fuel line and wrecked motors and chassis rails and one which sparked up and gutted the car i just dont think this is a diy job. Baileys will definately do it for you, they are doing one for me this week
regards
Echidna
posted on 18/10/08 at 08:21 PM Reply With Quote
Thanks Andy, please check your U2U inbox! Thanks!
Andy B
posted on 18/10/08 at 08:35 PM Reply With Quote
Oops - just got your U2u and noticed location so I am not sure my advice was very helpful, that said depending on budget if you want me to sort a new prop from baileys and ship it to you I will get a quote for you - would just need to know diff being used, full length, distance from sprocket adaptor to centre bearing and which prop adaptor pcd you are using.
Hope that helps
Echidna
posted on 18/10/08 at 09:45 PM Reply With Quote
I am afraid that i must have the engine in hand to give you most of the details you are requesting. Maybe we could arrange this by making a very good discount for one of your engines?
Echidna
posted on 19/10/08 at 01:21 PM Reply With Quote
Why not making a sprocket adaptor with the same 3-hole pattern so will need only to "adjust" the length of the prop and not making a new adaptor for the adaptor?
