Author: Subject: Making adjustable trailing arms
goodguydrew
posted on 23/10/08 at 08:48 PM Reply With Quote
What is the technique to making the end on an adjustable trailing arm?
Do you weld a nut into the tube end or tap a thread into the tube end?
Is a lock nut required to hold the shperical bearing in place?
Any advice / pictures welcome.
mark chandler
posted on 23/10/08 at 09:11 PM Reply With Quote
Make an insert that can be welded in to the tube and tap this.
Grind a fishmouth or a couple of V's in the end of the tube you will be inserting the sleeve in to so you will have a longer weld in different planes.
Also plug weld the insert a bit further back.
Use half nuts with the spherical bearings
blakep82
posted on 23/10/08 at 09:28 PM Reply With Quote
you can buy inserts from rally design (i did anyway) or billy mcgill on ebay
i bought the inserts, and then went to metal supermarket to find tube which was a perfect tight fit 25mm o.d with 2mm wall thickness if i remember right
[Edited on 23/10/08 by blakep82]
________________________
maartenromijn
posted on 24/10/08 at 06:24 AM Reply With Quote
For my panhard rod I used inserts from McGill, as above ^^^, and plug welded as above ^^^. I have drilled four (6 or 7mm) holes in the tube at the location of the insert. Then I have inserted the insert and welded up the holes. Also the end has been welded.
I have used an old bolt in the insert during welding, to prevent spatter damaging the thread.
It's hard to see on the pic, but to give you an idea:
[Edited on 24/10/08 by maartenromijn] Rescued attachment IMG_0069klein.JPG
BLOG: http://thunderroad-super7.blogspot.com/
maartenromijn
posted on 24/10/08 at 06:33 AM Reply With Quote
This is what I mean: Rescued attachment IMG_0069kleinpaint.jpg
Fred W B
posted on 24/10/08 at 01:08 PM Reply With Quote
Also as below, my detail before welding
Fred W B
rod end detail
rod end detail
goodguydrew
posted on 24/10/08 at 01:11 PM Reply With Quote
Thanks. That was very helpfull.
