Author: Subject: Under-dash-panel is one needed?
jps
posted on 3/2/18 at 11:17 AM Reply With Quote
Is it required to panel from the bottom edge of the dashboard back (I.e towards the engine bay)? If so, is this best done in the same way as the transmission tunnel or is it better to be easily detachable?
CosKev3
posted on 3/2/18 at 03:47 PM Reply With Quote
For IVA?
the bottom of the dash needs a certain radius on it,but there is no requirement for a panel otherwise.
40inches
posted on 3/2/18 at 05:36 PM Reply With Quote
They check with the sphere under the dash, so yes it needs to be paneled. I used plastic sheet.
loggyboy
posted on 3/2/18 at 07:44 PM Reply With Quote
There is an imaginary line drawn from underside of dash horizontally forwards, all thats above is tested with a 165mm sphere, and below a 100mm sphere. So its not essential but depends on whats above the line.
Mistral Motorsport
40inches
posted on 3/2/18 at 08:06 PM Reply With Quote
Yep! So fuse boxes steering shafts etc will be tested.
nelmo
posted on 3/2/18 at 08:25 PM Reply With Quote
Nothing under the dash was tested in my IVA last August and I can clearly see my fuse box and the main wires from the battery.
Ditto under the steering wheel, although I did put corrugated tube over the brake lines where they passed under the steering column (again, not tested).
Build Blog
CosKev3
posted on 4/2/18 at 09:50 AM Reply With Quote
Pretty sure they only check upto the vertical line level with the bottom of dash?
http://www.locostbuilders.co.uk/viewthread.php?tid=200814
[Edited on 4/2/18 by CosKev3]
loggyboy
posted on 4/2/18 at 01:26 PM Reply With Quote
On review the imaginary line is 150mm above the seat. But behind dash is still checked with 165mm sphere.
Mistral Motorsport
CosKev3
posted on 4/2/18 at 03:05 PM Reply With Quote
I would say items between the 150mm line and the vertical line from the bottom of dash are checked,hence the item shown in the pic being below the line from the dash?
