Author: Subject: How to redrill a hole?
Chaz
posted on 12/8/13 at 02:54 PM Reply With Quote
Hi, as you may guess from the title I'm relatively new to this practise.
I need to fill in a threaded hole on an alternator and then re-drill it about 5 mm offset from its present centre-point. I have heard people using words like, chemical metal and slugs. I need it to be load bearing, what should I do?
If you need pics to clarify, i can provide.
Thanks in advance.
[img] [/img]
[img] [/img]
[Edited on 14-8-13 by Chaz]
minitici
posted on 12/8/13 at 03:03 PM Reply With Quote
Normally tap the existing hole and screw in a suitable plug.
The plug can be epoxied, loctited and/or mechanically 'upset' to stop it coming out.
Then mark the new centre and drill the offset hole.
Depending on the material, the existing hole could be welded up and re-drilled.
Also worth thinking laterally and see if the other part of the mounting could be altered to suit the existing hole position.
Chaz
posted on 12/8/13 at 03:10 PM Reply With Quote
Normally tap the existing hole and screw in a suitable plug. The plug can be epoxied, loctited and/or mechanically 'upset' to stop it coming out.
By suitable plug, do you mean a bolt and then saw/angle grind it off?
By mechanically 'upset', do you mean damaging the bolt thread to prevent it from unscrewing itself?
Thanks again...
Bluemoon
posted on 12/8/13 at 03:11 PM Reply With Quote
I would avoid altering the hole position, as replacement would then become a PITA, adjusting the bracket is probably easier in any case..
dan
minitici
posted on 12/8/13 at 03:15 PM Reply With Quote
Thanks again...
Try and use the same material as the original plate for the plug i.e. Aluminium.
If steel then a suitable steel bolt (low grade not high tensile) might do.
To 'upset' the bolt you can use a centre punch to put dings close to the thread on the plate once the plug has been screwed in.
[Edited on 12/8/13 by minitici]
posted on 12/8/13 at 03:47 PM Reply With Quote
dan
Ditto, I'd look at mounting it differently or making a bracket up to suit.
Post up some pics of the alternator and intended mounting position and we might be able to offer some more suggestions.
fesycresy
posted on 12/8/13 at 03:53 PM Reply With Quote
You may be able to Helicoil it, depending on position.
But I'd alter the bracket too.
