Author: Subject: Duratec injector rail mod?
TrophyJem
posted on 28/2/14 at 12:28 PM Reply With Quote
Has anybody successfully modified the standard Duratec injector rail to have an outlet on the end to feed back to the swirl pot?
If so how have you done it please?
hootsno1
posted on 28/2/14 at 12:41 PM Reply With Quote
I bought a st150 one and drilled a hole in the end cut the feed pipe of the standard rail then got it welded to the st one
If a little hammer won't fix it get a bigger hammer
TrophyJem
posted on 28/2/14 at 12:44 PM Reply With Quote
I didn't know there were different types.
The one I have is like this. Dooable??
matt_claydon
posted on 28/2/14 at 01:00 PM Reply With Quote
Is there a reason you need to? Just put a T-piece in before the inlet and take your return from there.
TrophyJem
posted on 28/2/14 at 01:01 PM Reply With Quote
Didn't know I could do that. I assumed that the return needed to be at the end.
matt_claydon
posted on 28/2/14 at 01:06 PM Reply With Quote
Many cars look like that as they have the reg integral with the rail, but it's not required. See this thread for a bit more info:
http://www.locostbuilders.co.uk/forum/23/viewthread.php?tid=144667#pid1220897
In the diagram you can substitute 'tank' for 'swirl pot' if you are using one.
TrophyJem
posted on 28/2/14 at 01:17 PM Reply With Quote
I'll do that then. Saved me a job.
Cheers!
