Author: Subject: dashboard
Stuart_B
posted on 18/6/08 at 06:42 PM Reply With Quote
dashboard
hi all, i was thinking of making my dash and was wondering what to do with this bit?
picture below
thanks
chris_smith
posted on 18/6/08 at 06:45 PM Reply With Quote
can you put a cowel around it?
Stuart_B
posted on 18/6/08 at 06:47 PM Reply With Quote
the crowel i got from the donner is not long enough.
Benzine
posted on 18/6/08 at 06:53 PM Reply With Quote
that's pretty short, i went to a scrapyard for mine, only a quid
chris_smith
posted on 18/6/08 at 06:54 PM Reply With Quote
i see ^^^^
is the adjustable sierra column cowl not longer?? seem to remember reading something on here
eznfrank
I'm sure my column sits closer to the dash than that?? I'll go check later. The top of the standard cowling is quite short though.
Stuart_B
posted on 18/6/08 at 06:57 PM Reply With Quote
so do i need a new cowl?
where can i source one from or can i make one?
stuart
Benzine
posted on 18/6/08 at 07:04 PM Reply With Quote
Mark Allanson
posted on 18/6/08 at 07:28 PM Reply With Quote
I just glued ribbed rubber mat to the inside of the cowl and tucked it under the dash, looks really production.
posted on 18/6/08 at 08:30 PM Reply With Quote
I formed a bit of ally sheet, covered it with black vinyl and secured each side with a black self tapper into the plastic cowel. Have a look at Hellfires build site for pictures (I copied what they did).
Taylor R1
posted on 18/6/08 at 08:50 PM Reply With Quote
Dash Cowl
Had same problem. Bought a sierra one & shortened it.
See photo archive for pic
posted on 18/6/08 at 08:59 PM Reply With Quote
LOL - for SVA I cut two 2 litre Tesco value water bottles, glued together and covered in black insutlation tape! Got rid of it now but still not got round to tidying it up; it is exces weight anyway and the area behind the steering wheel is not tested othjer than wiring being secure.
skodaman
posted on 18/6/08 at 09:31 PM Reply With Quote
O2 lmao at ur avatar. I got a wall like that at bottom of garden. Nice to know it bites.
Skodaman
tim windmill
posted on 19/6/08 at 07:15 AM Reply With Quote
there are 2 sizes of cowl, the longer cowl is off the adjusatble column
