Author: Subject: Paddle Shift
Pdlewis
posted on 29/6/08 at 03:13 PM Reply With Quote
Paddle Shift
Hello,
After not finding a reasonably priced paddle shift kit i have decided to have a go at making my own (it can only go wrong)
Could of questions,
1. Does anyone have some rough dimensions i can use as a starting point? I only have a sierra wheel at the min and want to make sure its not to big once i downsize
2. How big should the center hole be?
3. Any suggestions on materials and thicknusses?
Paul
worX
posted on 29/6/08 at 03:16 PM Reply With Quote
1. Depends on the size of your (eventual wheel) some like 300mm, I preferred 275mm
2. Centre hole should be big enough to clear column (40mm) but also to rock from side to side. Hole therefore depends how much your paddle is going to rock, which also depends on your Pivot/Fulcrum points. (I made mine 50x70 ovalised, or something like that!)
3. 6mm Ali will do fine, or you could make one in CF?
tegwin
posted on 29/6/08 at 05:02 PM Reply With Quote
I made my own out of some scrap steel..
Make a cardboard template and try it...see if its right, then remake it....until you have a nice template...Took me a while..
www.verticalhorizonsmedia.tv
welderman
posted on 29/6/08 at 05:04 PM Reply With Quote
had this made up for mine, needs some more holes on it though
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=Image353.jpg
Thank's, Joe
I don't stalk people
mark.s
posted on 29/6/08 at 05:13 PM Reply With Quote
welderman what is the thinkness in the plate you used
[Edited on 29/6/08 by mark.s]
Pdlewis
posted on 29/6/08 at 06:03 PM Reply With Quote
Thats pretty sweet welderman.
How have you guys sleaved your steering column to attach the paddles?
Build Photo Album
Updated 05/02/2009
tegwin
posted on 29/6/08 at 06:23 PM Reply With Quote
I have a bit of exhaust tube which the steering shaft goes through...
I have welded some tags onto this tube for the paddle shift rose joints to bolt onto...
worX
posted on 30/6/08 at 05:06 AM Reply With Quote
They aren't great photo's but here's mine!
welderman
posted on 30/6/08 at 11:52 AM Reply With Quote
6mm ally, not finnished the thing yet, but i turner the all sleve off the column down to 42mm, and then i will sleve it again with some stainless tube Rescued attachment 2boss.jpg
Thank's, Joe
