Cinquecento steering rack question
dan8400 - 4/10/17 at 06:53 PM
Hi
Does anyone happen to know the measurement between the swivel ends on the cinquecento rack? May also be called the tie rod pivot width. As in the picture below:
https://goo.gl/images/bL7hYH
Dan
russbost - 5/10/17 at 09:25 AM
That's the rack we use on the Furore, unfortunately I don't have one on the shelf to measure, but approx measurement taken from one on the car is 360mm between the 2 rear faces of the rack swivels. Should you happen to need extensions for the rack tie rods we have them & they convert from the Fiat thread to the Toyota thread for Toyota TRE's as that's our main donor vehicle
The equivalent measurement on the image you gave the link to is 598mm (460 + 2 x 69), so as you can see the Fiat rack is tiny by comparison, hence why it's so suitable for our application
dan8400 - 5/10/17 at 10:38 AM
Thanks Russ
