Hub center steering...
akumabito - 17/1/05 at 08:25 PM
Just a bit more information for you trike guys out there that want "something different"...
Not new, definately different, central hub steering...
More info (also on suspension, and even hydraulic drive..):
http://www.eurosoft-ind.demon.co.uk/steering.htm
http://splashmedia.co.nz/users/britten/art3.html
http://www.tonyfoale.com/Articles/Hydraulics/Hydraul.htm
http://www.msoe.edu/library/senior_design/gateway_pages/hub_center_susp.shtml
niceperson709 - 17/1/05 at 10:38 PM
well this is a topic I know a bit about having built a couple of FEET Forward bikes and I am sure that trike builders would find the lack of steering lock with most HCS set ups a problem BMW telelevers would be better the scematic is I think for a bimota Tesi and if you are lucky it will have 20 deg each way .
best wishes
Iain
