Author: Subject: Eric Morin - Canadian ZX7 powered Trike
sgraber
posted on 10/12/04 at 12:00 AM Reply With Quote
http://community.webshots.com/album/171469295iZRuYS
He is a lot further along than this...
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
posted on 10/12/04 at 12:19 AM Reply With Quote
What rear tyre is he going to use across those two bike rims welded together? It's going to be a monster.
sgraber
posted on 10/12/04 at 12:25 AM Reply With Quote
This is what he wrote me some while back.
Reverse Trike design (two wheels front)
Base on a motorcycle Kawasaki Ninja ZX7R
Engine: 750cc ,128hp (race cam,jetting)
Dimension: Wheel base 90inch
Width: 78inch
Length:138inch
Height;ground to top 41inch
Ground clearance :4 to 5inch
Weight:800lbs
Front Wheel (2):205,40,16
Rear Wheel (1):Custom design 315,35,17 (modified motorcycle wheel)
Front suspension: Double wishbone , DOM tube , Tig Welded
Front hub: Modified mazda miata , 4 bolts Front spindle: Mazda miata Front
Hub hat: Custom design to fit motorcycle 11inch cross drilled disque Front
brake: 4 pistons motorcycle caliper , with balance valve Rear suspension:
modified motorcycle swing arm ,custom design Rear Brake 2 piston caliper
10inch rotor
Reversal gear box : custom reverse gearbox (made with VW transmission part)
Control: Howe clutch and brake pedal, CNC hydraulic Throttle, Custom pedal
box adjustable.
Steering: Removable steering wheel (wildwood)
Electronic: Custom design ECU , speedometer (converter from mechanical to
electronic pwm controller)
No ignition key , transponder design , with HONDA red start
engine and more ....
Frame: 1.5inch DOM round tube , 1inch square tube , tig and mig welded
Painting: Powder coating , suspension,frame 9I'm doing the powder coating)
Custom candy color for the fiberglass part.
Body part: Fiberglass , Kevlar laminated hood , Carbon fiber dash board and
side panel , air scoop.
Fiberglass rear module.
Equipment: Milling machine , Lathe , Mig,Tig,Stick welder,Powder
coating machine , and all the hand tools available
He is almost finished with it, but my link to his website is at home.
Steve Graber
Rorty
posted on 10/12/04 at 06:34 AM Reply With Quote
That's a proper job! I just love his rear wheel. That's how to get the traction down!
I wonder about his steering quickener though. There are several proprietry ones around that are both prettier and are adjustable for speed/ratio.
Cheers, Rorty.
"Faster than a speeding Pullet".
PLEASE DON'T U2U ME IF YOU WANT A QUICK RESPONSE. TRY EMAILING ME INSTEAD!
ChrisS
posted on 10/12/04 at 10:02 AM Reply With Quote
[Edited on 10/12/04 by ChrisS]
CD-5
posted on 27/3/05 at 12:54 PM Reply With Quote
can some one post his web site i'm curious?
Ratman
posted on 2/4/05 at 10:54 AM Reply With Quote
I love the concept of this layout of three-wheeler. It makes so much minimalist sense. I made a very crude trike once on this sort of layout and it suffered quite a bit from chassis twist, The rear wheel used to take on a noticable angle during cornering, and I wonder if this design might have some similar issues, which would be a real shame with all the flat rear rubber. The point is, that during hard cornering, the weight of the fuel tank and engine, above the single rear wheel, generates a lot of twist in the chassis that has to be accepted by the front axle. There is little triangulation in this chassis so far, that will provide torsional rigidity in an axial tension/compression manner. So, the torsional stiffness is only provided by the summation of the torsional stiffness of the several tubes joining front to rear. There are a lot of tubes, and I doubt that there will be a significant problem.. but a triangulated spine or similar would make it literally 100 times stiffer. Damn nice shape, and top markes for fabrication. Brian
Willie_H
posted on 17/2/07 at 09:33 PM Reply With Quote
Steve do you still have the website address. I would love to see this finished.
tigris
posted on 31/3/07 at 04:31 PM Reply With Quote
rear tire
aside from the "looks cool" factor is there any reason to have a rear tire this wide. I understand that there is more traction needed because the 3 wheeler doesn't lean, heavier weight . It would seem that anything much wider then 205 or so is overkill. Very ingenious though.
sgraber
posted on 1/4/07 at 04:30 AM Reply With Quote
Traction, track-tion, tracshun.
I wish I knew how this project has continued. I tried emailing Eric a while back, but it was returned as undeliverable. So Eric, if you ever read this, email me!
Graber
Steve Graber
kb58
posted on 12/4/07 at 02:46 PM Reply With Quote
This design suffers from a common problem. If the vehicle leans in a turn, which it will if the CG isabove ground, the big fat tire will also lean, lifting a corner slightly. Its traction will decrease since the tire is effectively becoming narrower, making it likely to spin. I don't know of a easy solution, and a leaning chassis isn't simple.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
tigris
posted on 15/4/07 at 04:08 PM Reply With Quote
swingarm
how about mounting your swingarm mounts (wouldn't work if you are using a sportbike frame) on a bushing, which would allow it to pivot a few degrees. I would think the chain drive could withstand the twist.
tigris
posted on 15/4/07 at 04:11 PM Reply With Quote
you'd also have to mount the shock on some type of rod end as well
Simon
posted on 7/5/07 at 12:14 AM Reply With Quote
It would twist with the pull of the chain or torque from a shaft, so either way it's a no-no I'm afraid.
Simon
tigris
posted on 10/5/07 at 10:41 AM Reply With Quote
twist
I thought about mounting the swingarm axle mount to a bearing vertical on the chassis, allowing only for movement relative to that axis. That way the chain could not pull the sprocket towards it on acceleration-any comments?
tigris
posted on 10/5/07 at 10:44 AM Reply With Quote
although the output sprocket and the swingarm axle pivot would have to be close to each other or there would be pull with compression of the shock.
