Author: Subject: Back to the drawing board
designer
posted on 26/8/12 at 07:20 AM Reply With Quote
Now back working on Simplicity. Looking at body styles:
profile?
profile?
[Edited on 26-8-12 by designer]
Chippy
posted on 26/8/12 at 09:43 AM Reply With Quote
Reverse trike by the look of it, nice shape but severely lacking on triangulation IMHO. Is that a BMW flat 2, or four cylinder? Like the idea though, just needs a bit more thought. Regards Ray
v8kid
posted on 26/8/12 at 04:38 PM Reply With Quote
Interesting point about triangulation.
Do 3 wheelers need any triangulation? After all the roll resistance at the rear is zero so there are no torsion loads transferred from the suspension. Presumably the ethos is light weight so every bit that can be discarded is a bonus.
The front suspension appears to be monoshock so will need lateral bracing if it is to work...
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
designer
posted on 26/8/12 at 08:15 PM Reply With Quote
Chassis is of 50mmX50mm and will be pannelled in aluminium sheet, side and bottom and will be strong enough.
The bike in the drawing is the BMW K1200RS, used because I could get CAD for it. But, any large bike can be used as the five bike mountings will be easy to manufacture.
More here:
http://www.shedworks.eu/simplicity.html
Chippy
posted on 26/8/12 at 09:52 PM Reply With Quote
More here:
That is quite interesting, hadn't really thought of paneling the tub but makes sense as that would then be a very stiff structure. So now get on with the build and keep us informed with loads of pictures. Cheers Ray
Dualist
posted on 27/8/12 at 07:20 AM Reply With Quote
Not keen on the front shock linkage, gonna be a lot of twist in that (poss make that middle bit into a triangle rather than a square with a load of gussets.?).
Though it would solve the need for an anti-rollbar.
Rotary build coming soon...
Originally posted by RichardK
I recently discovered that pigs can p i s s sideways when being transported
smart51
posted on 27/8/12 at 02:33 PM Reply With Quote
The mass at the single wheeled end of a trike tries to induce roll. The anti roll bar at the other end resists it. There needs to be some chassis stiffness to resist this torque moment.
clairetoo
posted on 27/8/12 at 04:17 PM Reply With Quote
That needs some more thought........I doubt it would even hold its own weight up , without folding in the middle (right at the bottom of the roll bar , where all the static load will be)
Remember - triangles are strong - rectangles are not .
Its cuz I is blond , innit
Claire xx
Will weld for food......
designer
posted on 28/8/12 at 06:10 AM Reply With Quote
The chassis will not break in half.
The bike is mounted at the head, at the top of the roll hoop, and at the bottom cross member with two mountings (not shown in the drawing), with the side extentions providing lateral support.
