Author: Subject: Indicators Flashing Too Quick
davidimurray
posted on 11/4/15 at 07:16 PM Reply With Quote
Just fitted some new bike indicators to the front of the roadster to replace the old bike indicators I had on. They are bulb type ones but when on they flash twice as quick as they should. Guessing I need a fixed rate relay - can anyone recommend a direct replacement for the sierra flasher module?
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Smoking Frog
posted on 11/4/15 at 07:32 PM Reply With Quote
Or maybe just up the bulb wattage.
40inches
posted on 11/4/15 at 07:48 PM Reply With Quote
Had the same problem, just replaced the 10w bulbs with 22w.
posted on 11/4/15 at 07:54 PM Reply With Quote
Yep - go to your nearest bike shop and get 22W bulbs of the same physical size (you won't find them in Halfords). I had to do the same for my front bike indicators.
[Edited on 11/4/15 by David Jenkins]
ali f27
posted on 11/4/15 at 08:24 PM Reply With Quote
+ 1 on the wattage
davidimurray
posted on 11/4/15 at 09:10 PM Reply With Quote
Looks like I need to work out how to dismantle those little arrow indicators.
Thanks for the advice everyone
ceebmoj
posted on 11/4/15 at 10:41 PM Reply With Quote
You can also get flasher units that don't rely on the load for the timing that work very well.
jossey
posted on 12/4/15 at 04:44 PM Reply With Quote
get an led flasher unit.
David Johnson
posted on 12/4/15 at 05:09 PM Reply With Quote
I added another set under the headlights to sort mine out.
Its all because the wattage is too low giving the flasher unit a lower resistance, ie: not enough load.
