IVA Fail
Kevin - 25/9/18 at 01:53 PM
IVA fail today at Exeter but still happy. The steering lock for some reason stopped working, the rear fog light needs to stay on even when main beam is on. The seats where the seat belt rest on needs to be 25mm higher and the head restraint 100mm higher, so pretty happy with that. The guy was just brilliant.
jacko - 25/9/18 at 03:30 PM
un lucky but well done
snapper - 25/9/18 at 03:51 PM
That is indeed a good fail
adithorp - 25/9/18 at 06:34 PM
Not a bad fail at all. Just look at it as a definitive "to do" list
gremlin1234 - 25/9/18 at 06:41 PM
yep well done, only a very short list.
time to get the registration forms from kits and rebuilds if you haven't done so already
(so you can fill them in, then send them off as soon as it passes)
SteveWalker - 25/9/18 at 10:47 PM
Originally posted by Kevin
... the rear fog light needs to stay on even when main beam is on.
I've thought that an odd requirement for some time - you can't have main beam on in fog or you just blind yourself!
[Edited on 25/9/18 by SteveWalker]
907 - 26/9/18 at 06:20 AM
One of my old tin tops had just that. Might have been a 1.8 Sierra.
Flip the dip switch to main and the rear fog went out.
