Author: Subject: wiring hazard
mat.price
posted on 26/12/08 at 03:05 PM Reply With Quote
wiring hazard
after the last post
http://www.locostbuilders.co.uk/viewthread.php?tid=100279&page=&contribmessage=none
i have manage to get all the wiring sorted from then
but now i having trouble with the hazard light switch now
everything seems to work ok but when i put the hazard switch on all the lights flash like there ment to but the hazard flash light dose not??
first i thought it was the light bulb but that work fine when i put the lights on and now im a bit stuck on what to do??
dose anyone have any suggestions??
Schrodinger
posted on 27/12/08 at 12:40 PM Reply With Quote
It sounds like you have the warning light wired up to the lighting circuit, which it shouldn't be. Which wiring loom do you have?
Keith
Aviemore
mat.price
posted on 29/12/08 at 03:37 PM Reply With Quote
i have the standed tiger avon wiring loom with the 6 fuses
Ian D
posted on 30/12/08 at 01:57 PM Reply With Quote
My reading of the wiring diagram is that the light on the hazard switch should not flash. To show you have your hazard lights on the two green indicator lamps on your dash should flash.
The hazard switch light should just come on when the lights are switched on so at night you cans see where the switch is.
the diagram is on page 119 of the tiger book.
hope I have read your question correctly.
Ian
Ian D
Ian
mat.price
posted on 30/12/08 at 02:53 PM Reply With Quote
your right but as i sayed before
the light would only go on if all the lights was switched on which is ok
but before it would flash with the green light at the some time when switch on if the lights was on
also when i truned it on with all the lights off it would turn on too??
ive been looking at different wiring diagrams and some people have cut into the one of the other wires cant remember which one
i have not modded any of the wire other then the fog light as i needed to do that for the sva
but if i get a chance tomorrow ill try again
