Author: Subject: Westfield Busa Turbo won't start (no spark)
mk1_salami
posted on 20/11/12 at 10:05 PM Reply With Quote
Hi guys,
I had hoped to join up here and my first post to be under different circumstances but hopefully someone can help me out. I bought a Westfield SEIW on Saturday which has been converted to run a Holeshot racing turbo hayabusa engine, with an MBE 9A4 ECU and what appears to be this harness:
I had the car at Knockhill and it was running fine all day, but in the afternoon it simply stopped working and came to a spluttering stop, spitting flames out of the exhaust. I've checked and the car is getting fuel, but there is no spark at all.
Does anyone have any ideas of what to check? My immediate thought was that the crank position sensor is faulty?
Nick DV
posted on 20/11/12 at 10:40 PM Reply With Quote
There could be plenty of reasons for this (stating the obvious) but this harness is like the one SBD use http://www.sbdev.co.uk/Hayabusa/hayabusa_wiring_management_systems.htm
Give them a call, I believe they are very helpful.
Cheers, Nick
"The force will be with you, always!"
paublo999
posted on 20/11/12 at 11:32 PM Reply With Quote
Do you have the programming cable?
If so, fire up the software and I would check for a crank signal first off
If not, I think you will end up buying one just so that you can diagnose stuff like this. Not cheap either as it hooks up via can.
Edit - are you central belt? If so drop me a pm and may be able to help.
Paul
[Edited on 20/11/12 by paublo999]
My videos http://www.youtube.com/user/ninjabogeyracing
twybrow
posted on 21/11/12 at 12:16 AM Reply With Quote
Check some of the obvious things first. Has the engine earth come loose? My BEC wouldn't start after a run out, and it turned out that the crimped engine earth cable had come out of the terminal - so no engine earth. Also check you haven't blown a fuse (you probably checked this already).
I find these are usually simpler problems than you first suspect! Good luck!
mk1_salami
posted on 21/11/12 at 08:27 AM Reply With Quote
Thanks for the help so far. I've checked the obvious things and can't see any loose wires. The chassis ground is firmly attached to the engine block. I can't see where the wire goes for the crank angle sensor, so I suspect that may be the problem. What does the ECU need to send a signal to the coils? I'd imagine it'd need to know when to spark, so if the signal from the crank is not working it'll not work.
I checked and the cable is £120 - lovely!
Going to have a better look at it on Saturday during the day and see if anything jumps out at me. What are the two relays in the loom for? I'd think one is for the fuel pump but not sure what the other is for.
Also Paublo999 - I'm in Fife so not a million miles away. Thanks for the offer. I'll see how we get on on Saturday and report back.
matt_gsxr
posted on 21/11/12 at 10:11 AM Reply With Quote
+1 for crank sensor (maybe cam)
paublo999
posted on 21/11/12 at 06:01 PM Reply With Quote
Don't panic if the cam sensor isn't connected as it may be running wasted spark. No worries regarding the cable. Would just plug in my laptop and see if we can get a crank signal.
mk1_salami
posted on 21/11/12 at 09:37 PM Reply With Quote
The cam sensor is plugged in, as is everything else that I can see. Do you have a CAN cable? As a side note - just been watching your hill climb videos. Makes me want to give it a shot! (when I have a working car of course!)
paublo999
posted on 21/11/12 at 09:39 PM Reply With Quote
Yes. I have the cable and software.
Pm me your details and we can look at getting it to you
