Author: Subject: puma engine
chaddy44
posted on 28/2/13 at 10:17 PM Reply With Quote
puma engine
just aquired a raw striker chassi and loads of parts has anybody ever fitted a ford puma 1.7 vvc zetec se engine ??
ludsonline
posted on 28/2/13 at 10:40 PM Reply With Quote
Got a whole puma if you want one?..
chaddy44
posted on 28/2/13 at 11:15 PM Reply With Quote
allready have one thanks
was going down the 2.0 zetec engine route but i have a puma 1.7 vvc zetec se complete car
2.0 zetec 130 bhp ish
1.7 puma 125 bhp ish
oh and did i mention i have a puma lol
ludsonline
posted on 28/2/13 at 11:22 PM Reply With Quote
Ok m8, Puma's do have great engines...
[Edited on 28/2/13 by ludsonline]
Jenko
posted on 1/3/13 at 07:22 AM Reply With Quote
A few have fitted them to sylva j15's, and mojos. I'm in the process of fitting one to my j15...if you read the start of my blog you can find a fair amount of information on them........as far as I know great little engine, and very very light and compact...decent sump, and gear box ratios in the puma are a little closer than a fiesta.
MY BLOG - http://westfieldv8.blogspot.co.uk/
DH2
posted on 1/3/13 at 09:25 AM Reply With Quote
Do a bit of searching on Zetec SE, and you should find the answers.
It is possible, wouldn't be as cheap as a Zetec E, since you need a bespoke bellhousing to connect to a Type9, and there isn't the proliferation of parts as with the E.
I'm building a tuned 1600 Zetec SE to put into my Stylus.
DH2
JimSpencer
posted on 1/3/13 at 09:27 AM Reply With Quote
Hi
Yup, quite popular in the Hillclimb and Sprint community as the class split is 1.7L for the roadgoing kits, plus can be pursuaded to make a lot of power.
wylliezx9r
posted on 1/3/13 at 10:12 AM Reply With Quote
The special addition racing puma had 150 bhp so shouldnt be hard to tune.
George Best
theduck
posted on 1/3/13 at 02:22 PM Reply With Quote
Set of individual throttle bodies and you will have a cracking motor! Altetnative is the racing puma manifold.
beaver34
posted on 1/3/13 at 05:17 PM Reply With Quote
1600 much cheaper and easier to tune and not VCT to worry about.
lightest 1600 production engine, that what i use in my car
black fingernail
Contributor
Posts 144
Registered 2/7/09
Location devon
Member Is Offline
Photo Archive Go!
Building: finished? scratch built book locost with 1700 puma
posted on 1/3/13 at 08:33 PM Reply With Quote
Yes , I've been running one for two years, very good, light, revvy, motor, it has got standard injection and type 9 box.
I built my own bellhousing using the front bit of the standard puma gearbox casing welded to the back bit of a v 6 alloy bellhousing, this works well, but as mentioned above, you can buy one from various sources.
I would reccomend it, the sump is a bit deeper, with that weird extra cover on the bottom, but you can make it poke out of the top a bit to allow for it.
It is a simple installation and apart from the bellhousing, it should'nt be any more expensive than a zetec E.
feel free to u2u if you need help.
chaddy44
posted on 2/3/13 at 08:47 AM Reply With Quote
has anybody got any pics
blackfingernail any pics of the bellhousing would be appreaciated
chaddy44
posted on 2/3/13 at 08:50 AM Reply With Quote
thanks for the offer if i get stuck may take you up on it
black fingernail
Contributor
Posts 144
Registered 2/7/09
Location devon
Member Is Offline
Photo Archive Go!
posted on 2/3/13 at 09:34 AM Reply With Quote
I'm going out for a ride today, so I'll get some pics when I get back.
Do you just want pics of the bellhousing?
black fingernail
Contributor
Posts 144
Registered 2/7/09
Location devon
Member Is Offline
Photo Archive Go!
posted on 2/3/13 at 02:56 PM Reply With Quote
I've just put some pics on my photo archive, I dont know how to post them on here. (I make things, I dont play on computers).
The bellhousing is quite buried but I'm sure you get the idea, by the way where are you?
chaddy44
posted on 2/3/13 at 04:33 PM Reply With Quote
many thanks for the pics
i'm in doncaster south yorks
Jenko
posted on 2/3/13 at 07:21 PM Reply With Quote
Interesting...my sump looks different to that one...also, did you use the standard ecu or an aftermarket one?.
black fingernail
Contributor
Posts 144
Registered 2/7/09
Location devon
Member Is Offline
Photo Archive Go!
posted on 2/3/13 at 08:38 PM Reply With Quote
I made the bellhousing, so I suppose its a 1off.
I used the standard ecu. I try to keep things as simple as possible.
black fingernail
Contributor
Posts 144
Registered 2/7/09
Location devon
Member Is Offline
Photo Archive Go!
posted on 2/3/13 at 08:44 PM Reply With Quote
Sorry I meant to add,- the pic is of the bottom of the bellhousing, it is the rear part of a v6 unit so it has a ribbed section, my sump has the extra cover on the bottom to give it a bit more capacity for the 1700.
Jenko
posted on 3/3/13 at 08:38 AM Reply With Quote
Ahh...just had another look, I thought the bell housing was the sump..doh...yes, same as mine.
beaver34
posted on 3/3/13 at 09:16 AM Reply With Quote
im near wakefield and run a sigma motor, your welcome to have a look and a chat, or if you want pics ive got hundreed of the build
chaddy44
posted on 4/3/13 at 08:22 AM Reply With Quote
thanks for that may take you up on the offer
