jacko
posted on 10/2/16 at 07:21 PM |
Garage roof's
BOX PROFILE ROOFING SHEETS-ANTI CONDENSATION-SLATE GREY COLOUR COATED
Hi all
has anyone used this type of sheeting and is it any good i don't want to have holes to let cold air in i want a sealed garage
the reason i am renewing the roof is because it leaks and drips
plutos3
posted on 10/2/16 at 08:04 PM |
I have it on my roof. done 8 years ago, you get the profile gaskets to close in the ends. I do have a small area of rus appeared bt this was my fault
because I should have touched up the scratch, I live right on the coast so the salt air attacted the scratch. I would use it again when I build my new
shed.
jacko
posted on 10/2/16 at 09:16 PM |
So you are saying its good for a closed no air circulation garage my garage is a pre-cast concrete 5m x5m and not very high
jacko
rash12
posted on 11/2/16 at 07:46 AM |
roof
beware of condensation a friend of mine has done his but we lined it with ply first and it seems to be ok
907
posted on 11/2/16 at 07:50 AM |
It's excellent.
My neighbour has it on his garage. I have it on my garden shed come summerhouse.
Fix it down with roof screws; the sort that have a rubber seal washer and drill their own holes.
Paul G
cliftyhanger
posted on 11/2/16 at 08:12 AM |
I would hesitate to make it an unvented garage, especially concrete. Where will all the water vapour go?
JeffHs
posted on 11/2/16 at 09:22 AM |
It's been on my roof (concrete garage) for 3 years now and condensation is no longer a problem at all. I don't have ventilation apart from
draughts where I haven't sealed it properly. A tip I learned too late is to burn off the flock at the gutter end to stop water wicking back. I
do get a bit of that, but I helped my son to re-roof his and used a blow lamp to burn off the flock - no problems at all. It's also strong
enough to walk on with no problem.
The only downside is the noise. Heavy rain drowns out the radio and apples falling onto the roof sound like a bomb going off. Several times last
summer I was concentrating on some machining job when I jumped out of my skin as an apple fell.
Consider having a translucent panel too - makes a huge difference (but don't walk on that!)
Mr Whippy
posted on 11/2/16 at 12:16 PM |
For a dry garage your best having lots of wall vents on side and the opposite of the prevailing wind, worst garages I’ve had were fully sealed and I
think cars actually rusted just as fast as being outside especially in the winter when the air is damp and the cars are cold, sometimes the cars were
just soaking wet, inside!
[Edited on 11/2/16 by Mr Whippy]
Ugg10
posted on 11/2/16 at 03:36 PM |
when I put my summer house up the advice was to put vents in one wall at the lower left and then on the opposite wall at the top right so you get flow
diagonally across the whole garage. These can be just round holes (1" and then put a metal/plastic louvre over it
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
