indykid
posted on 1/9/16 at 10:24 PM |
Stannah 300 stairlift LED diagnostics help
I have a stannah 300 stairlift that was fitted in our house by the previous occupants. It worked fine until the charger packed up a year or so ago.
I've since replaced the charger and on turning it back on, it cooked one of the TVS diodes on the chair swivel PCB. I've replaced the TVS
diode, but it's still refusing to move.
I have power to the main board, all the interlocks are closed and I have 14V at the switch terminals of the main PCB at appropriate times. On the main
PCB, there are 6 diagnostics LEDs. On first powering up, I have LED 6 on constant (5V supply ok, apparently) and LED 4 blinking (software ok, so i
assume the chip isn't goosed) which I believe is normal operation, however, on holding the chair switch for more than a second or two, I get LED
5 on constant. Pushing the direction switch doesn't energise any relays.
Do we have any stairlift technicians in the house that may be able to shed some light (no pun intended) on the fault indicated by LED 5? I've
done my best googling, but only managed to find the meaning of LEDs 3, 4 and 6.
We only wanted to keep it for my ailing Grandad and shifting furniture up and down the stairs. It's not worth throwing a load of money at but
before it's condemned, I'd like to try save it, especially if it only wants a component or two on the board.
Tom
stevebubs
posted on 2/9/16 at 08:50 AM |
Presume you've checked the fuses on the main board?
[Edited on 2/9/16 by stevebubs]
gremlin1234
posted on 2/9/16 at 12:45 PM |
I didn't find anything for the 300, but did fine this (note site is quite slow)
http://www.dolphinlifts.co.uk/images/library/documents/stannah-260-wiring-smaller.pdf
rgrs
posted on 2/9/16 at 01:21 PM |
Check the batteries in the chair, if it was without power for that long they are probably u/s
Roger
indykid
posted on 3/9/16 at 06:25 AM |
Thanks for the replies.
Steve, fuses on both boards have continuity.
Gremlin, thanks for looking and for the link, but I think the 260 must have a different led setup. The 300 only has 6 red LEDs so I didn't want
to infer anything from the 260 manual.
Roger, surprisingly, both batteries appear to be ok after a charge, but I'll double check.
rgrs
posted on 3/9/16 at 09:38 AM |
Also dependant on version, if it has a motorised foot plate this also has a separate battery
Roger
