the_big_1
posted on 30/3/19 at 01:13 PM |
Radiator ideas
Hi guys,
What radiators are a good fit for a Haynes etc using a 2L zetec engine.
Wont be used for races etc.
Cheers!!
ian locostzx9rc2
posted on 30/3/19 at 04:48 PM |
If you want a nice Ali one recommend coolex radiators Nottingham
the_big_1
posted on 30/3/19 at 04:57 PM |
Hi ya,
I did see their adverts etc but unsure which style, core size would suit
ian locostzx9rc2
posted on 30/3/19 at 05:26 PM |
They do seven style rads in different depths worth ringing them there very helpful normally have a stand at stoneliegh I think the rad I bought for my
striker was 55mm sorted my cooling issues with my car which I used on track and the road on there website it’s the polo derived radiator
[Edited on 30/3/19 by ian locostzx9rc2]
Myke 2463
posted on 30/3/19 at 06:30 PM |
Golf std rad, been using one for years without any probs 2.0 Zetec
www.adrad.co.uk/prices/prices.php?type=radiator&id=VW334&model=GOLF&make=VOLKSWAGEN £30.09 posted.
Be Lucky Mike.
ianhurley20
posted on 31/3/19 at 08:32 AM |
I used the golf one at first but it did not have an 8 mm air bleed pipe exit at the top of the rad which caused me a few issues clearing air from the
system. After 12 months changed to a Polo rad which did. Beware there are lots of different types of rads fitted to the polo for the different engines
and ages, the main difference being there are two different core sizes for the cooling area, you want the larger one.
the_big_1
posted on 31/3/19 at 02:31 PM |
Hi ya,
What is the core size of the bigger one and is there a way to tell the difference between the small and larger one?
Many thanks!!!
ianhurley20
posted on 31/3/19 at 04:45 PM |
Not doing the research for you - have a look at the sellers web site posted previously and find out what the sizes are, there are only two
the_big_1
posted on 31/3/19 at 05:29 PM |
Hi ya,
Sorry for the questions.
I did do as you say but found more than two hence the questions.
I found the also the following for Polo.
380 mm x 320 mm
430 mm x 320 mm
627 mm x 377 mm
648 mm x 326 mm
As well as many different heights.
posted on 1/4/19 at 02:55 PM |
Honestly don't recall the dimensions, but I used a 2nd hand Polo rad on my 2.0 Pinto engined MK Indy. Kept it perfectly cool and fitted just
fine in the MK nose cone as well. I used the car on the road not the track, but it never got close to over heating even sat in heavy traffic on a hot
day.
![](http://locostbuilders.co.uk/upload/a204202-P1020261.JPG)
drt
posted on 2/4/19 at 02:18 PM |
I am looking for solutions too for an atom-esque car...
here's my research...
Car l x h x d [mm, core size normally]
Micra K11 1.0...........................380 X 370 X 17
Panda 45pk 1992 0.9.................462 x 240 x 35
Panda fire 1994.........................520 x 250 x 34
Punto 55 1.1 1993.....................435 x 322 x 23
Deawoo Matiz 0.8......................458 X 294 X 16
Fiat Cinquecento 0.7 31pk..........312 X 214 X 24
Fiat Cinquecento 0.9 41pk..........248 x 465 x 34
VW polo III 1.0 45pk..................430 x 322 x 34
Civic V 1.3 75pk 1995................346 x 346 x 24
saxo mk1.................................390 x 322 x 23
Mini 1300 (pre BMW)..................400 x 280 x 40
Opel Agila A 1.0.........................377 x 378 x 34
Subaru justy 2001 1.3................330 x 350 x 16
Panda 1986...............................583 x 250 x 34
UNO 1.0 1992...........................312 x 340 x 32
Alto V 1.0 2000.........................325 x 360 x 18
swift 1.0 2001...........................408 x 341 x 34
austin mini................................250 x 270 x 30
Rover mini 1000........................285 x 260 x 42
GPZ600....................................300 x 187 x 32
GPX600....................................300 x 230 x 34
ZZR600E..................................350 x 220 x 34
1998 R1...................................335 x 300 x 42
Rover 45...................................520 x 400 x 20
VW polo II 1986 1.0 40pk...........380 x 322 x 38 Standard used by most locost builders
I have 2 of these polo rads brand new, never used, I'm thinking of using motorcycle ones as I need to fit them in side pods
the_big_1
posted on 2/4/19 at 07:14 PM |
Hi guys,
Managed to get one that most seem to use, just working on how to install now etc.
So now I guess its header tank time as previous ideas had a rad cap.
Does the standard polo one with the blue cap work, is it a pressure release cap??
Cheers all!!!
posted on 3/4/19 at 04:20 PM |
Vauxhaul Astra (probably mk2) expansion yank on my 2.0 Pinto MK Indy. Pressure relief cap and it worked perfectly with the rad, keeping everything
cool.
![](http://locostbuilders.co.uk/upload/indyfs_8.jpg)
