Author: Subject: Flywheel resurfacing
coyoteboy
posted on 24/4/20 at 11:35 PM Reply With Quote
So I'm tempted to challenge myself, at risk of buggering up my tin top flywheel.
I have a mill. I don't have a rotary table. Or a flywheel cup grind wheel. My local flywheel place wants £60 to resurface the wheel. Not a bad price, a bit steep maybe but i'm happy to support a local specialist before they all vanish.
However for ~120 I could get a rotary table, convert it to a 4th axis using my spare steppers and cup grinder and give it a try on my mill.
I just don't know whether my mill is stiff enough, or if I'm just giving myself another project I never finish
Anyone tried it before?
mark chandler
posted on 25/4/20 at 06:46 AM Reply With Quote
Definitely buy the bits and do it yourself, further down the road you will want to lighten a flywheel and find other uses such as skimming discs to minimum size to save weight.
I skim and lighten flywheels in my lathe using carbide to remove the bulk of the material then finish with a grinder.
[Edited on 25/4/20 by mark chandler]
coyoteboy
posted on 25/4/20 at 10:20 AM Reply With Quote
Sold, to the man who had a compulsive tool purchasing problem 😂
posted on 25/4/20 at 03:39 PM Reply With Quote
Good man, I like to buy tools as well
I do have few I've only used for one job, but I still enjoy buying them.
I've not done flywheels, but it seems you'll find other jobs to use the tools you buy for so go on and have a go.
coyoteboy
posted on 26/4/20 at 08:04 PM Reply With Quote
Bahh having taken the old clutch off there's absolutely nothing wrong with the fly - it's spotless after 175K miles - not even a wear step lol.
Ah well, tool order on hold. Might still get the RT for a 4th axis soon
