Type 9 vs GT 4 Spd length
82 Locost - 11/6/08 at 10:44 AM
If I were to change my 4 speed GT 'box for a 9 speed type 9 (short input shaft), how much would I need to reduce the length of the propshaft by if I wanted to keep the engine in the same position? (I'm aware I need to change the 'box end of the prop too).
Alternatively, what's the difference in the gearbox lengths? I've tried searching but can't seem to find the answer.
GazzaP - 11/6/08 at 11:31 AM
Mike
You would need to swop propshafts as the type 9 has a different input into the gearbox.
Do you know anybody who wants to buy a locost?
Gary
sorry just read ya post and you know about the end!!
[Edited on 11/6/08 by GazzaP]
82 Locost - 12/6/08 at 05:43 PM
So far I've found:
Type 9 = 760mm
Anybody know the lentgh of a type 2 (escort 4 spd)?
tcr - 12/6/08 at 06:17 PM
ive just measured my type e 4speed box total length from begining of input shaft to end of outputshaft is between 790mm/800mm i belive they are the same as rocket cause thats wot we replaced it with
82 Locost - 12/6/08 at 06:28 PM
Thanks a lot for the help.
82 Locost - 13/6/08 at 12:23 PM
For the record I've just managed to measure both types (on cars so not 100% accurate)
Type 2: 700mm
Type 9: 780-790mm
