I have a few more bits to clear out all Prices inc p&p (uk)
5x double hose clamps, Black aluminium, 13mm (8mm fuel hose etc). £15
[img][/img]
2x side repeaters, clear lens orange bulb £10
[img][/img]
38mm T-piece 25mm take off. £7
[img][/img]
Small breather filter, 10mm fitting £5
[img][/img]
Type 9 Gbox mount (narrow version) £15
[img][/img]
5x Toggle switches (3 on/off, 1 on/off/on, 1 on/on)
[img][/img]
Zetec plugs (4x injector plugs, TPS module, coil plug, crank sensor plug, temp sensor plug, idle control valve) £20
[img][/img]
R1 full injector loom £10
[img][/img]
Zetec coil plug. £7
[img][/img]
4X LED resistors 6.8Ohm
[img][/img]
£14 for the resistors.
Hi,
Please can you put me down for the following:
T piece
Breather filter
Toggle switches
Many thanks
Craig
T piece
Breather filter
Toggle switches
Now sold.
Could I have the pipe clamps and the side repeaters please?
U2U sent.
Thanks.
clamps and repeaters now sold.
