Author: Subject: Zetec Engine Parts FS
viatron
posted on 14/5/09 at 01:14 PM Reply With Quote
ETDWM
Linky
posted on 14/5/09 at 01:29 PM Reply With Quote
May I ask what upgrade you've done with the cams??
viatron
posted on 14/5/09 at 01:45 PM Reply With Quote
were actually going for full race crane cams. Power band 3.5k to 8k, hence the wet sump is being replced with a dry sump as well.
smac
posted on 14/5/09 at 02:04 PM Reply With Quote
Is the flywheel a standard cast one lightened or a pupose made steel one? What clutch is it drilled for?
[Edited on 14/5/09 by smac]
viatron
posted on 14/5/09 at 02:08 PM Reply With Quote
billet steel item drilled for the standard 7" clutch used to mate fords to a type 9, will throw in the clutch as well, not showing any signs of excessive wear but we are going to be using a tilton 5 1/4"
HTH
Mac
Danozeman
posted on 15/5/09 at 06:27 AM Reply With Quote
How much lighter is the flywheel? Is it 1.8 or 2 litre size? If itl take a standard mundano clutch i may be interested,
Have you got as piccie of that oil gauge aswell please.
[Edited on 15/5/09 by Danozeman]
Dan
viatron
posted on 15/5/09 at 02:10 PM Reply With Quote
the Tiger flywheel is approx 5 to 5.5kg and the original is approx 10kg, its was fitted to a 2.0 litre but fairly sure it wiould do a 1.8 litre as well
The gauge is gone im afraid
Mac
viatron
posted on 15/5/09 at 05:19 PM Reply With Quote
oil pressure gauge and flywheel sold
Mal
posted on 16/5/09 at 07:25 PM Reply With Quote
Sump
You have a U2U.
