Author: Subject: 6-Speed Gearbox + Duratec Engine + Pedal Box + MORE!
posted on 10/3/10 at 12:45 PM Reply With Quote
GEARBOX
Mazda 6-Speed (from latest model). Sold to me as having covered 5k miles. Never fitted or run by me. Looks very clean.
It can be used with a 2.0 Ford Durate engine (Mazda use the same engine but call it a 2.0 MZR)... just needs an MX-5 clutch / flywheel.
Does not need a bellhousing... fits straight onto the Duratec.
£475 + delivery if required (£50 to UK address).
gbox article extract
2.0 DURATEC ENGINE
Removed from a Ford Fiesta ST150 with approx 10k miles. The engine has been stripped back (so you don't have to) and comes with alternator, starter, dizzy, leads, original exhaust manifold and a single mass flywheel (not available on the standard engine). The EGR port has been blanked off. No injectors or fuel rail.
£445 + delivery if required (£50 to UK address).
Image deleted by owner
FORD RACING INJECTORS
41lb/hr (430cc/min) injectors - brand new
Will fit any 14mm o-ring 60mm centres application. Which is virtually all standard car injectors.... (EV6 style).
Retail at £50+ each over here.
£135 for the set of 4 + delivery if required (£4 to UK address).
MERC SLK ROLL-HOOPS
Dusty - need a good clean, but otherwise sound. Bought for a project that never got off the ground (who me?!).
£20 + Delivery if required (£5 to UK address).
ALI PEDAL SET + CYLINDERS
Custom ali pedal set (for cable clutch) with balance-bar and 2 x Girling MC's (0.7 and 0.625). Need a good clean, but a very nice bit of kit!
£135 + Delivery if required (£5 to UK address).
STAINLESS DURATEC EXHAUST FLANGE
£15 + Delivery if required (£5 to UK address)
[Edited on 11/3/10 by scootz]
It's Evolution Baby!
goaty
posted on 11/3/10 at 07:57 AM Reply With Quote
whats the dimensions of the gbox in comparison to a type 9? wondering if it will squeeze in my tunnel.
cheers
posted on 11/3/10 at 08:00 AM Reply With Quote
I'll get some dimensions this afternoon Goaty!
posted on 11/3/10 at 04:07 PM Reply With Quote
LENGTH
84CM
TALLEST POINT (NOT BELHOUSING)
26CM
WIDEST POINT (NOT BELHOUSING)
22CM
goaty
posted on 11/3/10 at 05:45 PM Reply With Quote
i shal check my tunnel 2mo.
thanks again
posted on 11/3/10 at 06:44 PM Reply With Quote
No probs! I can supply a bit hammer FOC it it helps to get it in there! :
T66
posted on 11/3/10 at 07:55 PM Reply With Quote
Scott,
I am interested in your pedal box.....
Ivo
posted on 11/3/10 at 08:03 PM Reply With Quote
Cheers Ivan! I'll hold it back for you to have a look at...
PS - Tuesday is fine with me!
posted on 11/3/10 at 08:33 PM Reply With Quote
Pedal Box still available!
posted on 15/3/10 at 01:54 PM Reply With Quote
Will do a deal for the engine and gearbox... £800 for both! It only needs induction, a gear selector and clutch / flywheel and you're off!
£50 if UK delivery is required.
Will also do the Injectors for an additional £100.
orton1966
posted on 15/3/10 at 03:24 PM Reply With Quote
u2u sent ragarding pedal box
posted on 15/3/10 at 05:39 PM Reply With Quote
Replied.
escary
posted on 15/3/10 at 07:01 PM Reply With Quote
pedals
u2u sent
posted on 15/3/10 at 07:37 PM Reply With Quote
PEDAL BOX SOLD!!!
Thanks!
posted on 16/3/10 at 10:24 AM Reply With Quote
All unsold stuff now on eBay...
posted on 16/3/10 at 10:43 PM Reply With Quote
ENGINE SOLD!
Veszpremi
posted on 17/3/10 at 03:39 PM Reply With Quote
Scott,
I'm interested in the injectors. Still available?
regards,
Peter
posted on 17/3/10 at 04:16 PM Reply With Quote
They are indeed Peter!
Veszpremi
posted on 18/3/10 at 05:49 PM Reply With Quote
[Edited on 18/3/10 by Veszpremi]
Veszpremi
posted on 18/3/10 at 05:52 PM Reply With Quote
Scott,
Is it possible to deliver it to Hungary?
Regards,
Peter
posted on 18/3/10 at 10:01 PM Reply With Quote
Sure... it would probably cost £10 to send them there (or if you can wait until June, then I can drop them off in Budapest!).
posted on 22/3/10 at 12:42 PM Reply With Quote
GEARBOX SOLD
posted on 22/3/10 at 12:43 PM Reply With Quote
EXHAUST FLANGE SOLD
