Author: Subject: For sale part 1
marmot0
posted on 8/4/10 at 06:31 PM Reply With Quote
For sale part 1
Team dynamic wheel 14 inch, 7j, PCD 108, ET25 shod with toyo proxis CF1 185/60/14 with 6mm tread left, in good condition 165 pounds
wheel1
wheel1
wheels2
wheels2
Honda prop adaptor to suit fireblade engines 30 pounds
sprocket adaptor
sprocket adaptor
Upper steering column turned down to take AB performance paddle shift 20 pounds
column
column
Sierra boss to accept various makes of steering wheel 20 pounds
Image deleted by owner
Luke 4 point harness with aircraft type buckle 40 pounds (also have matching 4 point harness with regular type buckle)
harness
harness
Motorsport 200 cell cat only used to get me through SVA 100 pounds
cat
cat
7 inch wipac headlights (pair) dip/main and side lights as fitted to Caterhams 75 pounds
lights
lights
Golf MK1/MK2 radiator brand new 20 pounds
rad
rad
Set of raw striker wishbones painted in black hammerite but counld do with stripping and repainting, fitted with ball joints and bushes
80 pounds
wishbones
wishbones
ETB fuel gauge and sender white dial red needle 30 pounds
fuel gauge
fuel gauge
Sierra stalks 5 pounds
sierra stalks
sierra stalks
Things already sold have been removed from the listing to avoid confusion
[Edited on 9/4/10 by marmot0]
tul214
posted on 8/4/10 at 06:49 PM Reply With Quote
u2u on its way re the harness
1.6 Raw Super6 sold
bodger
posted on 8/4/10 at 07:12 PM Reply With Quote
U2U re Mountney wheel & boss.
mistergrumpy
posted on 8/4/10 at 07:20 PM Reply With Quote
Can I have the Formula D wheel please?
I'll U2U you
marmot0
posted on 8/4/10 at 07:22 PM Reply With Quote
Gear leaver, fuel filler, removable boss, Moutney wheel now sold to locostbuyer83
marmot0
posted on 8/4/10 at 08:34 PM Reply With Quote
Formula d wheel now sold
ashg
posted on 8/4/10 at 10:02 PM Reply With Quote
has the sierra boss got the steering lock ring or is it the one without?
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
marmot0
posted on 9/4/10 at 06:48 AM Reply With Quote
Yes it has the notch cut out for the streeing lock
marmot0
posted on 12/4/10 at 12:26 PM Reply With Quote
The above items will be going on ebay in a few days, cheers
M$RK_VXRD
posted on 14/4/10 at 12:34 AM Reply With Quote
have you still got the fuel sender a guage?
marmot0
posted on 14/4/10 at 03:40 AM Reply With Quote
M$RK_VXRD you have a u2u
marmot0
posted on 17/4/10 at 02:03 AM Reply With Quote
Fuel Gauge and sender now sold
