Author: Subject: f/s various parts
JAMSTER
posted on 14/5/10 at 10:18 AM Reply With Quote
f/s various parts
4 core rad (used) sold to lars (stp)
lower column from a westfield seiw to go from sierra to escort rack sold to otodb thanks
sierra top column with ign switch 2x keys no light or wiper switches £10
zetec to type 9 starter motor £15
pinto starter £15
pinto ign module £10 with short loom
1997 escort zetec starter £15
duratec starter £15
all of the starters tried on battery in garage and work but not tested under load
bonnet scoop SOLD
1.6 pinto carb and manifold vac unit broken off carb £15
sierra engine mounts £15
all of the above subject to p+p at your cost collecton ok to
[Edited on 14/5/10 by JAMSTER]
[Edited on 15/5/10 by JAMSTER]
[Edited on 15/5/10 by JAMSTER] Rescued attachment P5110004.JPG
otodb
posted on 14/5/10 at 11:44 AM Reply With Quote
U2U sent ref:- lower column from a westfield seiw to go from sierra to escort rack £25
madrallysport
posted on 14/5/10 at 01:51 PM Reply With Quote
2nd dibs on steering column please
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
gavin174
posted on 14/5/10 at 02:55 PM Reply With Quote
1st dibs on engine scoop please
lid0n
posted on 14/5/10 at 03:39 PM Reply With Quote
u2u sent
martin62
posted on 14/5/10 at 08:16 PM Reply With Quote
Hi I would be intersted in the zetec to type 9 starter if you are willing to post to Ireland
JAMSTER
posted on 15/5/10 at 06:50 AM Reply With Quote
scoop sold gavin 174 thanks
JAMSTER
posted on 15/5/10 at 08:06 AM Reply With Quote
rad sizes the core is 70mm wide similar rad on westfield £176 Rescued attachment P5120005.JPG
JAMSTER
posted on 15/5/10 at 08:42 PM Reply With Quote
rad sold to lars subject to payment
thanks
JAMSTER
posted on 17/5/10 at 12:23 PM Reply With Quote
bttt
JAMSTER
posted on 25/5/10 at 12:16 PM Reply With Quote
Harlanite
posted on 26/5/10 at 09:13 AM Reply With Quote
about that column
I don;t suppose you have the bulk head clamp that held the column under the dash going spare do you?
dan_g8
posted on 26/5/10 at 07:58 PM Reply With Quote
u2u upper steering column
