Author: Subject: zx9r main jets and megajolt
cd.thomson
posted on 18/4/11 at 11:14 AM Reply With Quote
Hi guys,
Does anyone know the standard size of zx9r main jets and could someone suggest a supplier of replacement jets? Without looking inside them again im pretty sure they have non-adjustable needles, could anyone confirm?
With regards to megajolt, is it possible to create a reasonably pleasant ignition map without a RR? Does anyone have a map for a C20XE running bike carbs or the ignition map from their megasquirt running bike TBs I could try flashing to my jolt?
Thanks in advance
Craig
YQUSTA
posted on 18/4/11 at 11:27 AM Reply With Quote
Don't know the size of the jets off hand but your right the needles are non adjustable as standard.
Tiny washers may work for the needles.
"If in doubt flat out"
Colin McRae
cd.thomson
posted on 18/4/11 at 11:39 AM Reply With Quote
I actually need to lean the mixture out, so ill have to do it with the mainjets I think, with the needles being fixed.
Thanks for getting back to me
Craig
rich201283
posted on 18/4/11 at 01:09 PM Reply With Quote
I have checked my zx9r manual
B Model - 200
C Model -155
E Model - 60 &165
Which model carbs are they?
cd.thomson
posted on 18/4/11 at 02:43 PM Reply With Quote
I'm not sure to be honest, is that any way to check? Do you know of any jet suppliers?
Craig
macc man
posted on 18/4/11 at 04:06 PM Reply With Quote
Most people usually drill out the existing jets to a larger size. 1.6mm is a good startig point.Works fine on my 2.0 zetec on zx9r carbs. You can always go larger, or solder holes up and redrill if too big.
posted on 18/4/11 at 04:16 PM Reply With Quote
Dynojet kits have the adjustable needles you need, and different jet sizes.
Rule of thumb is the jet size is the same in mm.
140 jet is 1.4mm etc..
jacko
posted on 18/4/11 at 05:05 PM Reply With Quote
You don't need new needles you put small washers under the head of the needles
as said zx9r / e models have 2 sizes fitted in a set of carbs
I am talking about E model carbs
Jacko
mcerd1
posted on 18/4/11 at 05:25 PM Reply With Quote
model E ones look like this: (and have 'CVR' cast into the side of them)
the earlier ones look like these: (adn should have 'CVK' writen on them somewhere)
don't ask me how you tell a model B from a C though....
cd.thomson
posted on 18/4/11 at 06:24 PM Reply With Quote
thanks for the info everyone, just to clarify I'm trying to lean out the mixture. Once the engine comes off tickover its running too rich (5-6% CO). I think that means I need to reduce the jet size and any washers need to be removed rather than added.
I'll give dynojet a look, cheers!
mcerd1, don't forget I still have your IVA bars, sorry I've kept them so long mate. I'll return them once its IVAed or sold, get in touch if you need them sooner. I have the earlier model according to those pictures, thank you.
[Edited on 18/4/11 by cd.thomson]
Craig
cd.thomson
posted on 18/4/11 at 06:45 PM Reply With Quote
for future reference http://www.wemoto.com/bikes/Kawasaki/ZX9R_ZX_900_B3_B4/96-97/picture/Carburettor_-_Main_Jet/
Craig
mcerd1
posted on 18/4/11 at 09:59 PM Reply With Quote
I won't be needing the bars for a wee while yet I'm still rebuilding the garage for the second time at the moment
as for the carbs I've got a haynes manual for the ZX9R somewhere - I'll dig it out and send you the carb pages when I get a chance...
[Edited on 18/4/2011 by mcerd1]
