Author: Subject: Anyone know the Polo Fan Switch Pinouts
sucksqueezebangblow
posted on 21/8/11 at 04:37 PM Reply With Quote
Hi All,
My fan switch is not switching the fan on. I have wired it assuming the two pins are earth and switched earth to the fan but I have a sneaky feeling that the switch body may be earth and the two pins are two switched earths for a two speed fan? Is my hunch right should I be wiring to earth and one pinout? If so which is the lower temp pin and which is the higher temp pin? Any help appreciated!
big-vee-twin
posted on 21/8/11 at 04:45 PM Reply With Quote
Wire live to one pin, other side to fan, then second wire on fan to earth.
Its just a switch
http://www.triangleltd.com
Johneturbo
posted on 21/8/11 at 04:50 PM Reply With Quote
If it's just a 2 pin then it doesn't mater which way the wires are, the two temp switches are 3 pin
if you put the wires together the fan should come on.
RichardK
posted on 21/8/11 at 04:55 PM Reply With Quote
What the boys have said, this is a picture that may help. My fan is a 2 spead jobbie. Pretty sure the fan came off a mk2 golf like this VW MK2 Golf GL OEM Radiator Fan From A 1.8 8V GL - FWO | eBay although had to make a bracket.
Cheers Rich
[Edited on 21/8/11 by RichardK]
Gallery updated 11/01/2011
russbost
posted on 21/8/11 at 09:17 PM Reply With Quote
It's a switch - pure & simple!
norfolkluego
posted on 22/8/11 at 12:33 AM Reply With Quote
As said above, think of it as live in and live out (to fan) as the temp rises it completes the live circuit to the fan
sucksqueezebangblow
posted on 22/8/11 at 07:40 AM Reply With Quote
Ahh, okay, thanks all, looks like I may have a wiring or switch fault. I'd better get the multimeter out!
