Author: Subject: Solid bush materials
GavMax
posted on 17/4/12 at 09:37 PM Reply With Quote
Hi
I am thinking about making some solid bushes to experiment with the suspension.
Which is the best plastic to use for suspension bushes - is it Nylatron?
Also, would it be best to use a steel bush around the bolt or is Nylatron (or whichever plastic is suggested) sufficient without?
I should be grateful to receive thoughts and opinions.
many thanks
Gavin
posted on 17/4/12 at 09:44 PM Reply With Quote
From what I've seen you need an inner static crush tube on which the bush rotates otherwise the bush would wear very quickly on the bolt. You'd also not be able to tighten the pinch bolt enough with out deforming the chassis bracket and squashing the bush tight.
designer
posted on 17/4/12 at 10:02 PM Reply With Quote
Use either HMW1900 or Delin.
Polyurethane resists turning and can melt so keep stock in the freezer and if a sliding fit is obtained when turning, when the material is back at room temperature the fit will be perfect.
HowardB
posted on 18/4/12 at 06:01 AM Reply With Quote
Delrin is a trade name for homopolymer POM, copolymer POM, under the generic name of Acetal is less expensive.
hth
Howard
40inches
posted on 18/4/12 at 07:24 AM Reply With Quote
hth
And has the added advantage that it is very easy to machine.
Dale
posted on 18/4/12 at 12:34 PM Reply With Quote
Why not just oil tight bronze? on proper shoulder bolts?
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
