Author: Subject: zx9b carbs
andy188
posted on 11/9/14 at 07:31 PM Reply With Quote
zx9b carbs
hi all,
have fitted zx9b carbs to sons 2.1 pinto, running fast road cam, have changed jets to 1,5 as a starter point, idle screws out 2,5 turns, carb 1 running dry, carb 2 wet, 3 wet wet no 4 wet wet wet, popping back through exhaust and no 4 carb, have read about blocking air correction jet, whitch one is this, any ideas on how to fix before getting it to a rolling road for final setup.
maccmike
posted on 11/9/14 at 07:44 PM Reply With Quote
set the floats
davidimurray
posted on 11/9/14 at 08:09 PM Reply With Quote
Have you balanced them, if not your symptons sound like they need balancing.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
jacko
posted on 11/9/14 at 08:10 PM Reply With Quote
balance the carbs and 1.5 is a bit small for a 2.1 pinto mine was/ is 1.7 zx9r / e carbs
austin man
posted on 11/9/14 at 09:40 PM Reply With Quote
mine are 1.7 on a 1,8 Zetec
19sac65
posted on 12/9/14 at 03:23 AM Reply With Quote
Mine are 1.8 on a zetec
I would have thought it would run though,just not rev cleanly
If theres no fuel getting in i would make sure the carbs are clean,remove the jets and float valves and soak them
Is there fuel in the float chambers ?
davidimurray
posted on 12/9/14 at 05:49 AM Reply With Quote
Don't worry about the main jet yet.
Idle and pilot circuit controls roughly 0 to 20% throttle
Needle controls 20 to 75% throttle
Main jet controls 75 to full throttle
mcerd1
posted on 12/9/14 at 08:19 AM Reply With Quote
as above float heights and balance are the first things to check
but we might as well ask what fuel pump your using too ?
andy188
posted on 12/9/14 at 05:26 PM Reply With Quote
thanks 4 advise all, will check float height, we are using bike fuel pump, will buy a balancer as there are 3 kits in the family which will be running bike carbs, need to get a single intake one as pinto zx9 have been respaced, any recommendations?.
how can we confirm what model carbs we have?, have googled but not sure, these have no tps on them.
19sac65
posted on 12/9/14 at 05:30 PM Reply With Quote
You can find out if theres fuel in the bowl by undoing the drain screw in the bottom of the bowls
Without vac points on the manifold use a carb synchroniser for webers/ dellortos
On ebay for about £35
